It's wheel thing
Morrisun
It's wheel thing
Postby Morrisun » Sun Feb 16, 2014 1:27 pm
Saw these for sale and went in deep!
Magnesium 13 X 10, 4 on 4.5 and 3.375" of back spacing, there are in very good shape- just a wee bit of white corrosion on back of one spoke. Could not find a name or #'s, pair weights in at 27lbs. Time to break out the Gibbs Brand penetrant and clean them up.
Now just need to find a pair of 8" for the front.
Re: It's wheel thing
Postby izzo » Sun Feb 16, 2014 1:34 pm
good lord lol. never seen ones like that
MicroMachinery
Postby MicroMachinery » Sun Feb 16, 2014 2:54 pm
Be careful not to fall in.
Postby 510freak » Sun Feb 16, 2014 5:46 pm
:shock:
Damn 10" wide,thats sweet.
They appear to be the true blue ones too(with the ribbed brace in the center of the "spokes"
12honderd
Cars: 1200, nissan rouge
Postby 12honderd » Sun Feb 16, 2014 6:14 pm
Whoa sweet find doug! I thought my 13x9s were wide! Let ne know what tires you end up running on them.
Im pretty cool ask your mom
Postby DRIVEN » Sun Feb 16, 2014 6:15 pm
:shock: :shock:
Postby izzo » Sun Feb 16, 2014 7:21 pm
Those things are going to look amazing when cleaned up and polished with some fatty tires on it. I'd run white lettered tires with the car at a slight rake. Omnomnomnom.
Did you wash em up yet?
Morrisun
Postby Morrisun » Sun Feb 16, 2014 9:21 pm
I haven't decided on wither to polish them or not, kinda like the patina that is on them now. Need to get them oiled up and get the corrosion under control, moisture and magnesium don't mix very well as water is the leading cause of deterioration. They would look good very cool polished up, something more to consider??
Postby RedBanner » Mon Feb 17, 2014 1:13 am
Holy chit mang!
K_trip
Cars: DATSUN
74 Li'l Hustler L16/4spd
Postby K_trip » Mon Feb 17, 2014 4:42 pm
Wild ... I vote for cleaning them (phosphoric acid) and coating them with DOW 7 for that vintage racer look!
Morrisun
Postby Morrisun » Mon Feb 17, 2014 5:16 pm
I plan on treating them with, Gibbs Brand Lubricant- have a couple of cans on the way. Need to test if the wheels will fit into bead blast cabinet or not and then there's all that hand polishing. Not to thrilled about that part! Not familiar with DOW 7??
Postby RedBanner » Mon Feb 17, 2014 5:58 pm
Ive hand polish 7 wheels in the past 2 weeks... its not exactly fun.
Morrisun
Postby Morrisun » Mon Feb 17, 2014 8:29 pm
Red Banner, how much do you charge per wheel? Save for rainy days, I guess, if I have too...
Postby RedBanner » Mon Feb 17, 2014 9:11 pm
I dont offer that service. If I didnt do it by hand maybe, but I do it cause im broke, and wanted to do some work out of the rain.
K_trip
Cars: DATSUN
Postby K_trip » Tue Feb 18, 2014 6:49 am
Morrisun wrote:Not familiar with DOW 7??
Then perhaps you might want to read up on magnesium care?
http://www.magnesium-elektron.com/data/downloads/ds256su0.pdf
If you Google MAGNESIUM + DOW7 you should get plenty of information. It's a different beast than Aluminum alloys, and it looks like you have scored some rare ones - so I was suggesting what is considered "proper" for cleaning and refinishing them. Not only to make them look better, but to preserve them too.
Also - poor condition magnesium wheels can be very dangerous :shock:
Morrisun
Postby Morrisun » Tue Feb 18, 2014 7:30 am
Thank you for the information.
Morrisun
datsunfreak
Postby datsunfreak » Sun May 03, 2015 4:38 pm
So what happened? :)
Stuck in the 70s...
Morrisun
Postby Morrisun » Mon May 11, 2015 4:57 pm
I like the patina in the spokes and barrel of the wheels.
Didn't want to do the chemical strip- used Gibbs and Scotch brite pads on the machined front surfaces.
Still have half of a front left to do.
The backs, removed the white corrosion- coated with Gibbs and used Scotch pad just enough to remove old tire rubber. This is a trying process and do what the hands can handle! Hoping to have them done by Blue Lake in August.
Link to Gibbs info: http://www.roadsters.com/gibbs/#intro
K_trip
Cars: DATSUN
Postby K_trip » Tue May 12, 2015 10:22 am
They are looking nice! :thumbs:
In case you're not familiar with Magnesium wheel failure, look into it.
The folks who are serious about them will have them checked annually.
X-ray is one way. Dye penetrate and checking under UV light is another.
http://tpcs-magnesium-refurbs.co.uk/process-gallery.php
Morrisun
Postby Morrisun » Tue May 12, 2015 6:18 pm
K_trip:
Thank you for your well founded concern, I read most of the info from the link you posted as well as many others dealing with the testing/methods of/scary stuff-wheels coming apart!
I have had a CAT scan, and don't see an easy way to hiding one my surgical gown, let alone two!
I need to find a company in the greater Portland, Oregon area and find the cost of testing for cracks in magnesium.
The only tires I have found available that would work for autocross and an occasional track day are 255/40-13 Hoosiers, at about $235 each, 10" width rims in 13" tires are tough, not many to choose between...??
What started out as a fun little project has the potential of becoming a $1000.00 static display!
Rub on, rub off!
Return to “1200/B210/210”
