MD-Machinst 72-1200 (Mattndew76)
Re: MD-Machinst 72-1200 (Mattndew76)
Postby Laecaon » Thu Sep 18, 2014 9:33 pm
How do you plan to do that? With a broacher? I can't think of any other easy way.
Postby flatcat19 » Thu Sep 18, 2014 9:34 pm
Is that aluminum?
Mattndew76
Cars: 1200 coupe
Postby Mattndew76 » Fri Sep 19, 2014 8:40 am
Yeah I have to use a broach arbor. I have the .125" broach I just need the press now. Oh and make the 1.125 insert broach guide with shims.
FlatCat19 it is aluminum.
Postby RedBanner » Fri Oct 03, 2014 10:34 pm
With all the goodies you make, i want to sneak into your house and wisper " mechanical tachometer front cover for an aseries engine" into your ear while you sleep.
Mattndew76
Cars: 1200 coupe
Postby Mattndew76 » Sat Oct 11, 2014 9:46 am
I have to do a tach for the A12 in my car. So give me examples and this could be a reasonable item coming up.
Morrisun
Postby Morrisun » Sat Oct 11, 2014 6:36 pm
Matt:
You may want to take a look at this: http://datsun1200.com/modules/newbb/vie ... post426472
Morrisun
Mattndew76
Cars: 1200 coupe
Postby Mattndew76 » Sat Oct 11, 2014 8:53 pm
Fluffing awesome!
Postby RedBanner » Sat Oct 11, 2014 11:00 pm
One of my most desired items. It required. A proprietary oilpump shaft to operate a gear on the front cover there. That then 90ed into a cable. I saw one on a forklift years ago and have always looked for one.
Mattndew76
Cars: 1200 coupe
Postby Mattndew76 » Mon Oct 13, 2014 7:04 pm
The shaft is a super simple item to make. Metric shoulder bolt with a tig welded key drive on top. I want the worm gear drive for the tack cable!!
Adds:
Warner
http://www.texasindustrialelectric.com/ ... dapter.asp
Mini Cooper
http://www.minispares.com/product/class ... g9002.aspx
Mattndew76
Cars: 1200 coupe
Postby Mattndew76 » Tue Oct 14, 2014 7:37 pm
Return to “1200/B210/210”
