Looking for the following as either NOS or really nice used for my restoration in progress 520. Please note this is a very early 520, so some things may be different to even the later 66' trucks.................
Right turn signal assembly. I have a base, so if someone has the rubber, trim and lens, that would work also.
Rubber (?) plugs in the trans tunnel for the trans dipstick and trapazoidal hole behind the shifter. May be the same as 65' floor shift 320.
The castle nut that holds the Pitman arm to the steering gearbox. Got lost somewhere in the disassembly
Fuel door. Needs to have the little tab inside.
1 original 7" Toshiba headlight
Thanks, Mark
WTB: 66' 520 parts
- Has thanked: 409 times
- Been thanked: 1255 times
Re: WTB: 66' 520 parts
Your likely going to have to lower your standards a little, NOS is just hard to come by on a early 66, there are some clear front lenses on ebay right now, they may be NOS.
http://www.ebay.com/itm/Datsun-520-Turn ... 66&vxp=mtr
Here is one amber lense.
http://www.ebay.com/itm/VINTAGE-DATSUN- ... 5c&vxp=mtr
Sorry, but it looks like the amber sets were bought or the auction expired.
I cannot recall ever seeing the early rear lenses offered, in NOS or aftermarket.
I bought a set of aftermarket front turn signal assemblies off ebay a couple years ago, they come up every once in a while, if another set shows up, I would buy them if I were you, and if you find a NOS set later, well then that would be a win-win.
- Cars: 66' SPL311
- Has thanked: 25 times
- Been thanked: 109 times
Don't want clear and I have seen the ebay one, but it is a left and I already have an extra left. Believe me, I am well aware the difficulty of finding the early parts. Aim high and see what comes of it. I have seen NOS rear lenses, but of course that was like a few years ago before I had this truck. I do have a line on a NOS front signal assembly, but not quite ready to cough up the $$$ the seller wants yet.
Mark
Mark
- Ni10
- Has thanked: 119 times
- Been thanked: 24 times
got both amber front lens.jtinluvr wrote:Looking for the following as either NOS or really nice used for my restoration in progress 520. Please note this is a very early 520, so some things may be different to even the later 66' trucks.................
Steering wheel/ I would also consider a low windshield roadster steering wheel.
Rear taillight bucket/lens. This only has the red lights, no backup.
One 1300 fender emblem. This is not the same as the 521 1300 emblem.
The spring/screw/washer that holds the sunvisor arm to the mounting bracket. Same as above
Thanks, Mark
steering wheel - ?
got both 1300 520 front emblems but will make sure their not the 521 1300 emblems.
castle nut, prob do have.
as for the rubber plug and the spring/screw/washer for the sun visor, I'll check
none of these parts are NOS.
