73 1200 coupe, Twisted the Rebuild
Has thanked: 2 times
Been thanked: 2 times
Re: 73 1200 coupe, Twisted the Rebuild
#21
Post by RedBanner » Sun Aug 18, 2013 8:42 pm
It will be well worth it doug. Keep it up!
#22
Post by izzo » Fri Sep 26, 2014 7:14 pm
Any updates on this Doug?
kylezone
#23
Post by kylezone » Sun Oct 05, 2014 4:40 pm
agreed! i really want to see where this thing is going!
Morrisun
#24
Post by Morrisun » Tue Oct 14, 2014 6:24 pm
Well the rebuild slowed to a near halt as two thing have occurred 1) I have discovered late in life that I really like renegade auto-crossing (Northwest Autosports Association) and have improved a lot in this passed year- as stated by my mentor, who's been at it for 25 years.
And b) It hasn't rained like anything to talk about in the greater Portland area, in months, as I own a window cleaning company, I admit if I wasn't racing I was cleaning glass. That means I should have a few $$'s to put towards getting what little that's left of the body work done and getting it painted. Thanks to y'all for rattling my chain, it is easy to get distracted as I also want to build 1971 coupe into a street car with an A14, cam, carbs, yes the RX7 rear end that Klotz and I narrowed to go under Smurf.etc. Smurf is finally getting the front end lowered, coil overs, Koni struts, modified adjustable lower control arms, larger radiator, cam and side draft weber. I have gather together all but the struts and camshaft- though I have decided which profile from Delta cams I want them to grind for me. Good thing the weather is changing, after reading this, it's sounds like a full time job!
Later'
Morrisun
