Won't stop cranking
71Goon
Won't stop cranking
Postby 71Goon » Fri Dec 13, 2013 10:49 am
I went to start my car this morning and the battery was dead (my brake lights were left on from testing something). I tried to jump from my DD and all was fine at first (though it didn't want to start) but then after one attempt I released the key and it just kept on cranking. The only way I could get it to stop was to disconnect the battery. Did I fry my solenoid or starter maybe? Ignition switch? Voltage regulator?
I did recently pull my heater out as well, but I wouldn't think that would have an effect on starting - wires aren't connected but there are no exposed wires either.
If it's not one flippin' thing...
Thanks,
Tim
Re: Won't stop cranking
Postby draker » Fri Dec 13, 2013 11:24 am
Could be a mechanical issue with the starter... or it could be an issue with your ignition switch.
71Goon
Postby 71Goon » Fri Dec 13, 2013 12:20 pm
Must have been the solenoid - a few whacks with a hammer fixed it.
Tim
Postby izzo » Fri Dec 13, 2013 12:21 pm
lol. Time for a new starter mang.
71Goon
Postby 71Goon » Fri Dec 13, 2013 3:21 pm
Yup - there's a guy not to far away that has a gear reduction starter that I'm hoping to get sometime this weekend.
Postby 510freak » Fri Dec 13, 2013 3:23 pm
71Goon wrote:Yup - there's a guy not to far away that has a gear reduction starter that I'm hoping to get sometime this weekend.
:thumbs:
Gear reduction is the best way to go on a L motor,you will be glad you did
Postby 510freak » Fri Dec 13, 2013 3:24 pm
71Goon wrote:Must have been the solenoid - a few whacks with a hammer fixed it.
Tim
the bigger hammer fixes everything ;)
Postby Ni10 » Fri Dec 13, 2013 4:28 pm
when you was trying to crank it over and you let go of the key, did the key return to the run position ? Sometimes the ignition switch can get a little sticky from age.
71Goon
Postby 71Goon » Fri Dec 13, 2013 6:34 pm
Ni10 wrote:when you was trying to crank it over and you let go of the key, did the key return to the run position ? Sometimes the ignition switch can get a little sticky from age.
My ignition switch leaves a lot to be desired but it was definitely the starter.
datsunmike
Postby datsunmike » Sat Dec 14, 2013 9:54 am
Return to “Electrical”
