camber, with stock datsun parts.
Postby RedBanner » Fri Apr 22, 2016 10:38 pm
So there are a few datsun parts, for some models that have extra camber built in. If there are more please let me know
A b210 lca is almost 14mm longer than the stock lca for a 510,610,710, and other than that they are the same, so its a bolt in swap
Also, 75-77 710 strut tops have camber built in. And you can rotate them to get some castor in other cars. With these 2 items, you can change your suspension geometry a lot.
Re: camber, with stock datsun parts.
Postby izzo » Fri May 20, 2016 12:12 am
Indeed. good for the track. Not so great for daily driving, unless you like camber wear on your tires lol
Return to “General”
