ID this brake master cylinder?
Postby draker » Mon Nov 04, 2013 3:32 pm
Someone asked me to help them ID their master cylinder. They said it came out of a truck. It's a 3/4" master.
Pics:
Re: ID this brake master cylinder?
Postby 510freak » Mon Nov 04, 2013 3:43 pm
68 single reservoir,me thinks
Postby draker » Mon Nov 04, 2013 3:58 pm
Is there a truck this may have came off of?
Postby 510freak » Mon Nov 04, 2013 4:14 pm
That I wish I could help with,maybe 520/521 ?
Postby flatcat19 » Mon Nov 04, 2013 7:50 pm
521's? Metric or standard thread?
datsunmike
Postby datsunmike » Mon Nov 04, 2013 8:12 pm
520/521 had throttle cable not linkage. Never seen that style reservoir used back that far... usually just a tube shape. Looks like an L16 motor with the straight out block vent tube. Car I would think so, must be a 510? Can't find a single brake master for them, did they have singles?
Might be a truck master though. Wayno???
Postby 510freak » Mon Nov 04, 2013 8:13 pm
datsunmike wrote:520/521 had throttle cable not linkage. Never seen that style reservoir used back that far... usually just a tube shape. Looks like an L16 motor with the straight out block vent tube. Car I would think so, must be a 510? Can't find a single brake master for them, did they have singles?
yes 68s had a single master(brake)
** edit 68 510s
datsunmike
Postby datsunmike » Mon Nov 04, 2013 9:23 pm
Ah... Had a '68 and a 72 521... don't remember.
Postby flatcat19 » Mon Nov 04, 2013 9:30 pm
Is this in a 510?
Look at the threads.
510-metric.
521-SAE.
Postby wayno » Mon Nov 04, 2013 9:31 pm
It looks to be an auto, as I see no clutch master in that photo, also that firewall mount is definitely not a 521 firewall.
Postby 510freak » Mon Nov 04, 2013 9:39 pm
datsunmike wrote:Ah... Had a '68 and a 72 521... don't remember.
yeah not many 68s with a single master left, Most upgraded to the dual and disc,. Byrons ole Blue might still?
flatcat19 wrote:Is this in a 510?
510-metric.
521-SAE.
99.9999999% sure is a 510
Yes metric
Postby Laecaon » Mon Nov 04, 2013 9:41 pm
I remember Marios barn find wagon had a single res MC. Also had the SSS intake. Heard the single res was used on the SSS...
Postby 510freak » Mon Nov 04, 2013 9:43 pm
Laecaon wrote:I remember Marios barn find wagon had a single res MC. Also had the SSS intake. Heard the single res was used on the SSS...
this is a possibility
68's up here came single master, pretty sure it was standard issue across the board in 68?
datsunmike
Postby datsunmike » Mon Nov 04, 2013 9:47 pm
wayno wrote:It looks to be an auto, as I see no clutch master in that photo, also that firewall mount is definitely not a 521 firewall.
I couldn't be sure. You can see a bolt but might be the block off plate.
Postby flatcat19 » Mon Nov 04, 2013 9:50 pm
Draker said guy said it came off a truck.
Postby 510freak » Mon Nov 04, 2013 9:53 pm
flatcat19 wrote:Draker said guy said it came off a truck.
I see strut tower
:fry:
Postby flatcat19 » Mon Nov 04, 2013 9:53 pm
I see people missing the point.
Postby wayno » Mon Nov 04, 2013 9:54 pm
The 520/521 residual valve/brake line point straight up coming off the master, and they are SAE, that 4 bolt plate that the master bolts to is not from a 520 or 521, and the 520/521 all had cable throttle linkage like Dmike mentioned.
Postby 510freak » Mon Nov 04, 2013 9:55 pm
flatcat19 wrote:I see people missing the point.
:fry:
If it is off a truck,wayno would most likely know?
Return to “General”
