Forum rules
Post
by izzo » Tue Sep 10, 2013 8:59 am
datmo wrote:you win
You both win
KlassicMotion
#22
Post
by KlassicMotion » Tue Sep 10, 2013 9:10 am
Yeah sorry, I didn't intend to "show" anyone up, only that I've got some experience in the matter..... And to show another choice for materials and technique.
Post
by izzo » Tue Sep 10, 2013 9:37 am
I like them both. Datmo is young, so him doing shit on his own, trial and error is awesome. Keep at it man! Klassic, looks like you've done this a time or two. Gives people inspiration and some insight / knowledge on how to, a different way and some ideas. Both are good
I def like the two piece design. gives it some sexy lines
KlassicMotion
#24
Post
by KlassicMotion » Tue Sep 10, 2013 11:27 am
I started by recovering bench press and other work out equipment cushions, using similar materials to Datmo's process. You just pickup tips and tricks along the way.
datmo
- Cars: 1968 510 sedan. 1979 620 KC
#25
Post
by datmo » Tue Sep 10, 2013 9:00 pm
i DEF wanna try out the two tone type of design. you killed it with the door panels.
totally inspired to do some better stuff with my rear deck.
you think the foam and vinyl uou used would work on a piece of wood?
its a 2x4 kind of thing that some one cut and put in the car.
i painted it black but want to cover.
KlassicMotion
#26
Post
by KlassicMotion » Wed Sep 11, 2013 12:46 am
I think I know what material your talking about. It should work. Hit it with some 200-400 grit sand paper to give it a little tooth and take down the imperfections. The back deck of that Firebird in the picture is MDF that the owner had spray painted. The glue worked just fine on that. Just make sure you you follow the directions on the glue. Most people don't realize that contact glue needs about 5 minutes to get tacky before joining both sides.
To fasten the panels, I used some fasteners like these:
I've got an Au-Ve-Co catalog with about 50 different styles of these. National Fabric sells them. I like this for how flat the top is. It shows less under the foam. There are others that are better for other reasons. I still cut out a mm of foam that goes over the fastener, so it doesn't show. Just remember to insert the fasteners, before you glue the foam down!
datmo
#27
Post
by datmo » Wed Sep 11, 2013 8:48 pm
this would help a lot.
i always seem to have trouble when putting on door panels.
do you hae any of those door handles washers?
I'm in need of one and don't exactly know where to get it.
