CHEAP and easy wiper linkage bushing replacement
Forum rules
PDX Matt
Post by PDX Matt » Tue Sep 03, 2013 10:54 pm
If your linkage is anything like mine, the plastic bushings have either broken or worked their way loose. My issue was both and earlier today when I quickly turned the wipers on/off I heard the inevitable snap. Took off the cowl and indeed my 30+ year old bushing had broken. I was afraid that I was going to have to special order some specific parts online but decided to check out my local auto stores anyways. I actually find a solution that's cheap and effective.
I found an assorted wiper linkage bushing kit at O'Reilly's made by HELP! Part number is 49447.
Inside there are various bushings, however the one you need is this one. The new one compared to the broken original.
The assortment costs $4.50 and includes 3 of the bushings shown above. Fits perfectly and got my wipers functioning once more. If anyone needs a cheap and simple replacement for their wiper linkage bushings I recommend going this route.
Re: CHEAP and easy wiper linkage bushing replacement
Post by flatcat19 » Tue Sep 03, 2013 11:19 pm
Good post, Matt!
