Yes ! 100% agreed ! None of this BS cooling fan modules or alternator clutch pulleys designed to extend the life of a $12-$15 belt.
Yet another scam/Garbage
Country slice
- Has thanked: 665 times
- Been thanked: 243 times
Re: Country slice
Re: Country slice
Nobody gives a fling post update. New aisin water pump/thermostat into wifes daily. Probably wont be touching these recent replaced parts again.
Re: Country slice
Not much of anything , just a repair. Typical home stuff.
Noticed some bubbling of water/air between an expansion joint. Looked at the valves/pipes next go the home. Those weren’t it.
Re: Country slice
Got a tool or two delivered
Result ? Apparently this joint was the culprit. Got lucky.
The tool worked pretty decently especially considering doing aggregate. The 3.5 gallon (small) water pressure bottle for the wet cut D blade saved the day.
The existing compression coupler ? Yeah...literally tightened up the nuts , and it stopped leaking. Ordered more parts (locally didn't have anything).
- Has thanked: 1187 times
- Been thanked: 1156 times
Re: Country slice
Definitely could have been worse.
Re: Country slice
110% luck of placement , and type of leak. Feeling fortunate
- Has thanked: 1320 times
- Been thanked: 222 times
