KA24 rebuild?
Farmer Joe
KA24 rebuild?
Postby Farmer Joe » Sat Oct 04, 2014 3:20 pm
welp, the time is upon us to try and take this KA apart soon.
ive got a 93 d21 KA single cam in the truck.
guess my first question is the main and rod bearings between all the KA variants. are they the same or are there specific sets for certain KAs?
secondly, can i use single cam s13 rods with the truck crank?
overall goal is to use s13 pistons to bump the compression up in the truck engine.
id like to have that compression bump to go with the s13 cam i have.
thanks!
KLH620 KA24DE FS5W71B HF37
Farmer Joe
Re: KA24 rebuild?
Postby Farmer Joe » Sat Oct 04, 2014 6:51 pm
welp, nevermind..
found what i was looking for..
http://www.ka-t.org/forums/viewtopic.ph ... gine+specs
truck KAs have bigger main and rod bearings than the s13 counterpart.
so it looks like im stuck with 8.6:1 compression..
i guess another question would be, can 240sx pistons be used on truck rods?
Re: KA24 rebuild?
Postby Laecaon » Sat Oct 04, 2014 10:38 pm
I think so... Just would have to have the small end modified for a floating pin...
Re: KA24 rebuild?
Postby DRIVEN » Sun Oct 05, 2014 1:07 pm
Are you looking for a custom combo or just need to freshen up a tired engine?
Farmer Joe
Re: KA24 rebuild?
Postby Farmer Joe » Mon Oct 06, 2014 12:16 pm
mainly a rebuild on a tired engine..
seeing if i might be able to do a cheap or free compression upgrade, but im not too worried about it.
KamikazeGarage
Re: KA24 rebuild?
Postby KamikazeGarage » Tue Apr 26, 2016 3:45 pm
One thing to keep in mind, is Nissans bearing grading system. The block should have numbers 1-4 next to the mains, and respectively on the crank. Sometimes you can get by with STD bearings, if you can take material off with a micropolish
Justinberni
Cars: 1986 720
Re: KA24 rebuild?
Postby Justinberni » Fri Apr 29, 2016 10:15 am
KamikazeGarage wrote:One thing to keep in mind, is Nissans bearing grading system. The block should have numbers 1-4 next to the mains, and respectively on the crank. Sometimes you can get by with STD bearings, if you can take material off with a micropolish
your a couple years late man.. haha
KamikazeGarage
Re: KA24 rebuild?
Postby KamikazeGarage » Sun Jun 05, 2016 12:08 pm
Shit, well at least itll be there for future searches lol.
Re: KA24 rebuild?
Postby Laecaon » Sun Jun 05, 2016 12:55 pm
I got away with STD bearings. Either my CA had no miles, or the cranks just dont wear.
Return to “Engine/Drivetrain”
