1979 kc named Lulu
Re: 1979 kc named Lulu
#41
Post by Laecaon » Sun Mar 16, 2014 11:18 pm
flatcat19 wrote:
datmo wrote:I'm really hoping to find a damn 620 hub.
http://www.grantproducts.com/products/a ... 5/25/467/1
If only it wasnt a grant hub. Stupid 5 bolt pattern.
#42
Post by Laecaon » Sun Mar 16, 2014 11:20 pm
Idea, see if your 510 and your 620 match splines.
datmo
#43
Post by datmo » Mon Mar 17, 2014 9:23 pm
Laecaon wrote:Idea, see if your 510 and your 620 match splines.
I already tried but like the nrg hub, the spline part won't pass the threads that ab olt screws on to. :(
well thankfully the place i bought the hub form let me return it after some conversation for full price so I'll just buy a 620 boss hub off ebay.
It'll take awhile but I still have work to do too.
My 620 dash bezel also broke today when putting in my radio. was kind of really disappointed.
I wasn't even using much force and half the thing popped off.
I think it comes off from removing the gauges in the back but 'I didn't have enough time to play with it.
I got my radio into the spot but I still need to wire and put in my speakers.
i was thinking rustoleum's seafoam green for the color.
#44
Post by Laecaon » Mon Mar 17, 2014 9:36 pm
Everyone breaks their dash bezel. Everyone. There really should be a PSA about how not to break it.
datmo
#45
Post by datmo » Mon Mar 17, 2014 10:16 pm
Laecaon wrote:Everyone breaks their dash bezel. Everyone. There really should be a PSA about how not to break it.
Lol that makes it a bit better. I wanna paint it or make it unique.
I also got my lip today. Its the camaro lip. I think it looks badfucking ass. Ill figure out how to mount it sunday.
datmo
#46
Post by datmo » Tue May 06, 2014 10:19 pm
havent been on this shit for awhile but painted winter grey and did not turn out too nice but looks really mean.
I'm gonna repaint it some day for fun. Enjoyed it plenty and picked up some diamond steelies that are 16x8 and fit well.
pics!
interior is more stickered up. this thing's a rat and i love it.
Image Image
the door is just dirty in this pic..
Has thanked: 1320 times
Been thanked: 222 times
#47
Post by Taterhead » Thu May 08, 2014 9:19 am
Personally I like the grey better than blue.
#48
Post by izzo » Thu May 08, 2014 12:55 pm
I like the overspray on the tires.
#49
Post by Laecaon » Thu May 08, 2014 4:55 pm
izzo wrote:I like the overspray on the tires.
nobody can beat my overspray!!!
#50
Post by izzo » Thu May 08, 2014 6:14 pm
lol i was thinking of your dime when i wrote that :rofl:
datmo
#51
Post by datmo » Thu May 08, 2014 9:06 pm
Taterhead wrote:Personally I like the grey better than blue.
Thanks!
I wanna spray it a nice cherry red or something. I think it'd look good.
I bought some nicer fitting diamonds. I got rid of those old rollers
datmo
#52
Post by datmo » Sun May 18, 2014 2:04 pm
having issues. the truck is stuttering pretty bad.
I replaced my fuel pump and i had a water leak so i replaced that too but nothing....
any ideas?
#53
Post by Laecaon » Sun May 18, 2014 2:21 pm
checked the fuel filter?
Probably timing/fuel related.
#54
Post by izzo » Sun May 18, 2014 2:36 pm
Clogged jet, hole in fuel line letting air get sucked in, water in tank, fuel tank could need cleaned. I'd guess fuel, could be spark...
Pull rotor and check contacts n see what they look like, check plugs too, they new? Use NGK nothing else.
datmo
#55
Post by datmo » Sun May 18, 2014 3:07 pm
izzo wrote:Clogged jet, hole in fuel line letting air get sucked in, water in tank, fuel tank could need cleaned. I'd guess fuel, could be spark...
new ngk plugs.
new lines. maybe a cleaned fuel tank?
i checked all i know.
#56
Post by izzo » Sun May 18, 2014 3:59 pm
if you are un sure of fuel tank, run a line to gas can. problem is if it did by chance suck shit up theres a chance there is crap floating in bottom of bowl... hard call man... did you rev it out a bit and see if it went away?
check your choke too
datmo
#57
Post by datmo » Sun May 18, 2014 4:22 pm
izzo wrote:if you are un sure of fuel tank, run a line to gas can. problem is if it did by chance suck shit up theres a chance there is crap floating in bottom of bowl... hard call man... did you rev it out a bit and see if it went away?
yes i did and the car seemed the same.
it seems to drive alright but first is still having stuttering issues.
#58
Post by izzo » Sun May 18, 2014 6:21 pm
double check your wiring on the matchbox dizzy. make sure spark isnt able to jump somewhere... make sure you have a ground going from the spade on the matchbox side near the vac advance too. i heard missing those could cause issues. Take some effnig photos of what you have going on so we can seeeeee
datmo
#59
Post by datmo » Sun May 18, 2014 9:23 pm
izzo wrote:double check your wiring on the matchbox dizzy. make sure spark isnt able to jump somewhere... make sure you have a ground going from the spade on the matchbox side near the vac advance too. i heard missing those could cause issues. Take some effnig photos of what you have going on so we can seeeeee
will do wed since that's the next day i have off to work on the truck.
thanks in advance
#60
Post by Taterhead » Mon May 19, 2014 6:39 am
Is it sporadic or constant? Only when getting on it or when idling also?
Sounds like water in the gas to me. Run it empty and see.
