Bratmobile aka slick willy
- Jamee
- Title: Fluffer
- Cars: 1977 Datsun B210
- Has thanked: 3 times
- Been thanked: 10 times
Re: Bratmobile aka slick willy
This gasket is fucked. Cylinder 1 are of gasket is broken and mashed up. Plus because of being mashed it was hanging over the hole
- Has thanked: 1177 times
- Been thanked: 1152 times
Is that the correct intake gasket?
Glad you found an obvious cause. On the up-side, that piston sure is clean.
- RedBanner
- Title: MasterBlaster
- Has thanked: 2 times
- Been thanked: 2 times
That is the incorrect gasket i believe, good work.
Woohoo Jamee!
- RedBanner
3 gear pull video required!
on the up side. A series head gaskets are easy as fuck.
Very!
Did you reset the valves when you got her to operating temp?
thats no incey wincey spider
