L series 5 speed wanted
- Justinberni
- Cars: 1986 720
Got me a new 620, I'll start a thread for it soon, but I need a 5 speed and if someone has one for sale and is attending blue lake this weekend I'll bring cash moneyz. 4 speed sucks balls
- Has thanked: 410 times
- Been thanked: 1257 times
Re: L series 5 speed wanted
I have a 620 type 5 speed, but I don't have a L block front case for it.
It had a diesel case on it till I sold it recently, the oil in it wasn't the greatest, it was kinda dark, but there were no loose metal pieces, this transmission actually came from Australia and was used to trot horses at a track.
What year is your 620, does it have a short or long shaft 4 speed transmission, because if it has a long shaft, you can use the front case on this transmission.
- Justinberni
- Cars: 1986 720
I don't know if it's a short or long tail, ill have to crawl under and find out later
- Justinberni
- Cars: 1986 720
I just read that all 74-79 620's are long tails, so let's talk to some business at blue lake Wayne, and I'll swing by and buy it from you after.
- Has thanked: 1181 times
- Been thanked: 1154 times
Dogleg = racecar
I my experience, "dogleg = broken down piece of shit", but that is when it is in a truck.
Mine was in a 1200. Racecar.
A block?DRIVEN wrote:Mine was in a 1200. Racecar.
Yeah. A15. Originally pulled dogleg from '77 B210.
I have never heard of the A block wearing out the dogleg transmission, but then they put the L case on one and put it into the 200SX which worked fine also, but then folks started to use them in their trucks, 5th gear in the dogleg is not made for that type of heavy duty work, it starts to howl in no time at all under load, Dan Hart told me when I bought a Dogleg from him, he said when I load the truck up, use 4th gear, that is all he said, and he was so right.DRIVEN wrote:Yeah. A15. Originally pulled dogleg from '77 B210.
They are fine in cars, but are not a good choice for a truck.
- Justinberni
- Cars: 1986 720
I've heard they aren't too bad unless you haul any weight or have any power more than stock, but I'm just looking for a regular five speed
