LZ23 engine build
Re: LZ23 engine build
Postby flatcat19 » Thu Sep 01, 2016 5:18 pm
All I have here is a W53. No help to offer.
Postby wayno » Fri Sep 02, 2016 10:23 pm
Postby flatcat19 » Sat Sep 03, 2016 4:46 pm
Wouldn't you need a 720 L20B pan?
Postby wayno » Sat Sep 03, 2016 5:44 pm
flatcat19 wrote:Wouldn't you need a 720 L20B pan?
What I have in it is working, so I will measure it again and figure it out, I have quite a few oil pans around here, one of them will work, if not then I will use the one in there now, just won't be perdy. :lol:
Postby wayno » Sat Sep 03, 2016 5:56 pm
Oh yea, the ARP stud kit came today, Yea! :)
Postby wayno » Sat Sep 03, 2016 7:43 pm
Postby Taterhead » Sun Sep 04, 2016 3:37 pm
Not sure if this will help you or not Wayne but this is a U67 head
This is a "210" head
Postby wayno » Sun Sep 04, 2016 4:00 pm
Postby wayno » Sun Sep 04, 2016 4:11 pm
I messed up and posted in the wrong thread, I will save this spot for my next post. :)
Postby wayno » Mon Sep 05, 2016 2:55 pm
Postby wayno » Mon Sep 05, 2016 9:15 pm
Postby wayno » Sat Sep 17, 2016 8:59 pm
Postby HRH » Tue Nov 29, 2016 9:26 pm
Postby wayno » Tue Nov 29, 2016 9:48 pm
By the way, this LZ23 engine is still sitting in the same exact spot it was a month ago. :lol:
Postby HRH » Tue Nov 29, 2016 10:11 pm
Postby wayno » Tue Nov 29, 2016 10:18 pm
Postby Laecaon » Wed Nov 30, 2016 10:11 pm
Postby HRH » Thu Dec 01, 2016 12:17 pm
Good point, hadn't thought about that.
Return to “Engine/Drivetrain”
Who is online
Users browsing this forum: No registered users and 0 guests
