Taterhead wrote:The way you work you should have all that done by 2:38 a.m. On Thursday
Adam's annoying ass green 620
Progress will be swift I am sure
- Eagle_Adam
So I sat and stared at it for a half hour or so
Got acquainted, took in what looks to be needed for a smog delete, and power steering delete
I need a good FSM that covers the DE motors well. Suggestions?
Maybe a link to a PDF
- Eagle_Adam
I also got this header in the deal
I have yet to be able to determine if it will work with my swap or if I need to buy an exhaust manifold too
Ask, and ye shall receive.Eagle_Adam wrote: I need a good FSM that covers the DE motors well. Suggestions?
http://forums.nicoclub.com/240sx-fsm-fu ... 11075.html
- Eagle_Adam
thank you micro!
- Eagle_Adam
quick update:
header may or may not work... wont know till we get to the test fit
KA 5 speed will work just need to remove the speed sensor and replace it with a gear and im good to go
L series and 5 speed thats in the truck will go up FS to fund the swap
im am going to regasket the KA while its out (brave choice huh?)
- RedBanner
- Title: MasterBlaster
- Has thanked: 2 times
- Been thanked: 2 times
"I think I will regasket it while its out." Eagleadam before his first l series rebuild.
And his second...
And 3rd...
Etcetera etcetera etcetera
Lol
And his second...
And 3rd...
Lol
I would. I would even do a bearing change if affordable at the moment.
anyways, I'm learning Eagle CAD at the moment... For this...
- Eagle_Adam
its kinda odd...... having the feeling of "i dont know what the fuck that does" again
i think i could rebuild an L series blindfolded... the KA... kinda scares me a lil
- Eagle_Adam
ya.... the motor was running so i dont know if im gunna go that far, but i might. Still undecidedLaecaon wrote:I would. I would even do a bearing change if affordable at the moment.
thank youLaecaon wrote:anyways, I'm learning Eagle CAD at the moment... For this...
- Eagle_Adam
just double checked....
the motor had 144k on it
- Eagle_Adam
found a good write up on the PS delete
http://www.ka-t.org/forums/viewtopic.php?t=34921
figured id share what another member found for me!!
pass it on
pass it on
- Eagle_Adam
timing kit - check
gasket kit - check
new headbolts - check
gasket kit - check
Bawww yeah.... When I find another KA, gonna be doing teh same thing.........
- Eagle_Adam
fuel pump is next, ive read about whalboro's but some ppl say they are loud.... and a noisy pump would be annoying
pick n pull wants $25 for any pump in the yard, im thinkn about just finding something with an inline pump and a 2.4 L motor and calling it good.
figured id buy a fancy pump when i add boost
Who's gonna hear it when the truck is running? I'm sure that thing will have a phat exhaust and it will be nobody. Only hear a little whine right before you hit the button for startup
- Eagle_Adam
ive read of 510 guys with 2.5 in exhaust hearing it in their trunk...
and the whalboro is $100
JY pump is $25
JY pump is $25
I have heard sooooo many people make similar claims. Then they get rid of the Wahlbro. Its not just the sound, its the vibration. And for this reason I wont use a Wahlbro.izzo wrote:Who's gonna hear it when the truck is running? I'm sure that thing will have a phat exhaust and it will be nobody. Only hear a little whine right before you hit the button for startup
- Eagle_Adam
lolz..... ive created EX's for less.....izzo wrote:Only hear a little whine right before you
