Adam's annoying ass green 620
#161
what what in the butt
If i part out this hardbody ill make you a deal on the front end, yo. big brake upgrade!
Eagle_Adam
#162
Post by Eagle_Adam »
im good.....
i just want 4 wheel discs and my KA done.......
and then for realz, i dont wanna fuck with the truck anymore till paint/boost
Eagle_Adam
#163
boom!
timing kit and gasket kit are here!
time to tear into the motor
devilsbullet
#164
Post by devilsbullet »
doesn't have a part number on it that I can find, Its a carter, the only 280z carter fuel pump I found looks kinda like it but is slightly different. I can send you a picture of it if you want.
#165
the hardbody stuff is a straight swap over man.... Instant big brakes, really easy. Four wheel discs will be good, but big front brakes with turbo KA would be better, jus sayin. Then you can later on do the belltech 2 drop spindles if you wanted. (can now anyways lol)
Has thanked: 1354 times
Been thanked: 236 times
#166
izzo wrote:what what in the butt
:fry:
:shock:
Eagle_Adam
#167
looks like a made a trade!!!!
these should be running behind my titans before the swap is done!
#168
I'm sorry did you say something? i was to busy staring at your brakes jerking off.
Eagle_Adam
#169
nothing important izzo, carry on
#170
Eagle_Adam
#171
a little less exciting but still crucial
new headbolts :)
#172
Aww man, no ARP head bolts?
Eagle_Adam
#173
no, not this time around
Eagle_Adam
#174
EGR delete plate came in today
#175
EGR is for pussies anyways. I'll like my unburnt fuel out the exhaust, it's like coffee in the morning.
Converted_to_datsun
#176
Post by Converted_to_datsun »
izzo wrote:the hardbody stuff is a straight swap over man.... Instant big brakes, really easy. Four wheel discs will be good, but big front brakes with turbo KA would be better, jus sayin. Then you can later on do the belltech 2 drop spindles if you wanted. (can now anyways lol)
Do the hardbody breaks clear with 14's? If they do it sounds tempting :fry:
#177
I think so. Isn't the hardbody stock 14" rims? I put the hardbody up for part out, someone snagged the front brake setup already
Converted_to_datsun
#178
i did a little research and you need 15's to clear, too bad. Lol i love my 14's so i guess i'll stick with single piston calipers
#179
I don't think that's correct man. the stock hardbody rim is 14 inches.... Unless it's just aftermarket rims that don't work
#180
The stock Hardbody rims are offset around the calipers to fit them.
Dual piston HB clappers won't fit most 14" wheels. And some 15s don't work either.
Offset is key.
