Adam's annoying ass green 620
#441
Paint it black. Don't let anyone under your truck.
Fixed.
Solution #2
Place DMT stickers all over it and beat the ever living piss out of it on ever bump/hole you find.
Problem?
I'm assuming one from a '75 short bed won't work.
Eagle_Adam
#442
Post by Eagle_Adam »
flatcat19 wrote:Paint it black. Don't let anyone under your truck.
Fixed.
Solution #2
Problem?
A. I don't give a fuck what anyone else under my truck thinks about it so black paint won't help....
B. The only DMT in my life has nothing to do with mini truckn ;)
c. You are correct, I need a 78/79 tank
#443
I'm wondering if were thinking of the same DMT that isn't the DMT I originally spoke of.
:fry:
Eagle_Adam
#444
I knew what u ment, would u put a DMT sticker on ur 210?
#445
Eagle_Adam wrote:I knew what u ment, would u put a DMT sticker on ur 210?
I'd put it in their tail pipe.
NEBER!!!
Eagle_Adam
#446
may have found another tank!!!!
WOOT
also dropping off my rear axle shafts to have the backing plates removed and new bearings pressed in :)
#447
Sweet man. nobody really ever does the rear bearings. They have just as much wear as the front if not more from heavy loads (tho the front has an engine all the time) Haven't really come across a bad one in my datsuning. but it surely can't hurt.... with your axel out, should have them reset the tension and such in your pumpkin to make sure its wearing correctly too. Anyone can swap out the gears, but setting them right is another thing...
Eagle_Adam
#448
not interested in spending more $ right now....
and to be honest, this is not the last rear axle i plan on putting in ;)
Ni10
Has thanked: 119 times
Been thanked: 24 times
#449
Post by Ni10 »
so you needed a 78/79 620 standard cab gas tank ? But you found one ? :fuu:
are the standards and KC the same ????
well, if it isn't the right one, think I got one. just so's you know, K :fyea:
Eagle_Adam
#450
Ni10 wrote:so you needed a 78/79 620 standard cab gas tank ? But you found one ? :fuu:
ok...... this gets really confusing. so lemme try again
I have a 78
the truck i pulled my new tank from was titled a 78........ but wasnt actually a 78 (vin swap)
some 77's and all 78/79 trucks have FRAME mounted tanks
Soooooooo i need a frame mounted tank
the only difference i know of so far is that long beds are unique
BUT YOU HAVE A TANK FOR ME SO IT DOESN'T MATTER!!!!!!!
right?
Ni10
#451
Post by Ni10 »
like this ??
removed from a 78 620 standard cab.
Eagle_Adam
#452
BOOM!!!
that be it!!!!
hows the bottom look?
how much?
Ni10
#453
Post by Ni10 »
it's got a few dents on the bottom. :fuu:
I got to take off here soon, let me get another pic (bottom of tank ) for you when I get back from the store.
how soon do you need it. might be heading your way this month.
Eagle_Adam
#454
i need it sooner than later...
where are you located?
Ni10
#455
Post by Ni10 »
S.E. Washington
Eagle_Adam
#456
thats too far for me right now :/
lemme see what the bottom looks like, im afraid it will look like the one i have
Ni10
#457
Post by Ni10 »
Eagle_Adam wrote:thats too far for me right now :/
OK, but if by chance you do score one, please post that you got one. If you haven't by the time I head to the Couve, I'll bring it with me.
Eagle_Adam
#458
can you post a pic of the bottom, and when are you hitting the couve?
Eagle_Adam
#459
mmmmmmmmm new wheel bearing
look ma! no backing plates!
Ni10
#460
Post by Ni10 »
Eagle_Adam wrote:can you post a pic of the bottom, and when are you hitting the couve?
prob not much better then yours.
not sure yet on the Couve trip. Still working on a few details. Hoping before Christmas.
