Jacob's goon build
Re: Jacobs goon build
#241
Sourced a pair of 280zx struts, same part number as my struts. Now just need to find a time to meet up!
Also gonna order my T3 stuff tomorrow!
#242
Ok, I got my 280ZX struts. They are a bit rusty looking, so I need to spend some time with them. But correct camber ftw.
Didnt order the T3 stuff... I asked for an invoice since Gabe said he would knock $20 off since I wouldnt be using the top hats that come with the coilovers. He never sent me an invoice. Ill call tuesday probably.
Last day at my current job is Thursday. I start the new job next Monday. I should get my final paycheck Thursday (that is ORS law) and Im not sure if I get paid for my vacation time or not (2 weeks, but its dependent on what the work handbook says), if I dont then I didnt play my cards right with requesting time off...
dislexicdime
#243
Post by dislexicdime »
If your not using the tops then Why not just buy cheep coilovers off e bay?
kittens and bj's
#244
Because eBay coilovers come with super strong springs and to buy springs that I want is just going to put me in the ball park of just ordering from T3. I have researched coilovers for the past few years, I just can't get what I really want.
#245
Well, since you will be doing machine work now...
Can the rest of us get the coilovers you want?
#246
Im sure I will be making a few products, just not sure what.
The company is totally down with their employees using the equipment for personal projects/side job.
Also, T3 paid for!
Driven, want to sand blast my struts?
RedBanner
Title: MasterBlaster
Has thanked: 2 times
Been thanked: 2 times
#247
Post by RedBanner »
I can thro a set in the pile, if sandblasting 4 struts is probably as easy as 2
:fyea:
RedBanner
#248
Post by RedBanner »
Laecaon wrote:Sourced a pair of 280zx struts, same part number as my struts. Now just need to find a time to meet up!
What is this part number? And there are numbers on the hub is it the tube numbers (I figure they are) or the hub numbers (back of the cast bottom portion.
#249
Laecaon wrote:Driven, want to sand blast my struts?
Maybe. If you aren't in a hurry. Looks like it will be dry Saturday.
Has thanked: 1354 times
Been thanked: 236 times
#250
Not sure if it will help Adam but the part numbers on the 280zx strut I have in my truck is this:
As it looks on the front of the tube:
NISSAN 54303 P9100
TOKICO 2 2 10
As it looks at the bottom of the strut on the back. On the casting part where the tie rod bolts below the tube:
113-2 (nissan symbol) L
H
The only numbers I see on the hub are like this:
2 (stud here) 3
These came off of an '82 model.
Sorry for the TJ. Hope it helps
#251
There are a few that work... Mine are:
NISSAN 54303 P9100 drivers side, NISSAN 54302 P9100 passenger side. Cant imagine the tube being a different part number from the cast spindle...
#252
Saturday is a great day for me!
#253
Laecaon wrote:There are a few that work... Mine are:
I just have the one in my truck right now so I dont know if the other one is 54302 like yours or not.
The number on the back of the spindle I'm not sure what it's for. The spindle doesn't have a different part number that I'm aware of. I was just posting all of the numbers I could find on it.
RedBanner
#254
Post by RedBanner »
Exactly like mine, 303 and 302 Cool. Thanks yall.
#255
You can drop them anytime between now and then. Just leave them in front of the shop door. I assume they're stripped down and degreased?
#256
DRIVEN wrote: You can drop them anytime between now and then. Just leave them in front of the shop door. I assume they're stripped down and degreased?
Ok. Yea, ill strip them the best I can. Degreased? I dont think there is much grease on them... but Ill clean them the best I can.
#257
By stripped I just meant springs, calipers, rotors, etc. removed.
#258
Yea, for sure. I need to remove the spring perches anyways. Inserts need to go. Hubs are already off.
#259
Well...
#260
And you won't be using those BAD ASS camber plates?
