I am planning a mild build for my B210's A15. I have a bogg brother's manifold and kirk racing headers so I know that I will be port matching the head, but what other head work is important for the best flow on a street build? I will be boosting my setup in the future (M45 supercharger and yamaha R1 Boost Box), so while I'm rebuilding the engine, should I worry about increasing valve size?
I also plan to contact Delta Cams to have my cam reground, but I'm not looking for a high revving engine. This will be a quick street car with very little to no track time. Do you guys have any tips on a proper grind for street use (staying around 6-6.5k max rpm) with higher exhaust duration for superchrging?
