Hidden from J.S.
- Indy510
- Has thanked: 27 times
- Been thanked: 132 times
I took a few weeks off the coupe ... the rust got worse, but I wanted the wagon to be drive-able before I started the coupe's paintjob
- Indy510
Went back and forth between a Harbor Freight air compressor or Craftsman .... got this 26 gallon one on sale for Memorial Day:
It came with a impact gun and air ratchet:
- Indy510
I tired wire and razor blades to remove the rear windshield .... but this 150 lb test spider wire, fishing line (not wire) .. worked amazing
.... it will cut through your hand, even though it feels like soft twine:
Would some fix that goddam like button already!
- Indy510
You can see where the mini-tub welds warped the quarter .... but it's not too bad:
