Hidden
Indy510
Has thanked: 27 times
Been thanked: 132 times
Re: 1975 710 wagon KA24DE
#21
Post by Indy510 »
The wheels were 16x7 +22 and 16x8 +12 Panasports .. with 195/40 and 215/40/16 staggered Yokohama S-drives
Indy510
#22
Post by Indy510 »
Has thanked: 431 times
Been thanked: 1301 times
#23
That is a nice looking Wagon. :)
Indy510
#24
Post by Indy510 »
Thanks ..... but the dirty engine bay wasn't really "matching" the clean exterior:
Indy510
#25
Post by Indy510 »
Indy510
#26
Post by Indy510 »
#27
What was the processes and products used for the engine bay cleanup? Came out really nice.
Indy510
#28
Post by Indy510 »
I think I just used simple green, soap, and warm water,, and probably turtle wax after that.... The motor/intake got steel wool and Mother's aluminum polish.
Indy510
#29
Post by Indy510 »
My old 510 needed the suspension, brakes, and wheels to roll .... so the 710 struts went back on this giant wagon:
Indy510
#30
Post by Indy510 »
I got a CX racing radiator and fans, with the shroud, and it's a VERY low quality radiator ... too thin and not tall enough, but it seems to cool okay with one fan on most of the time.
and I modified a 240sx intake tube, by shortening it and moving the IACV outlet:
Indy510
#31
Post by Indy510 »
Indy510
#32
Post by Indy510 »
Indy510
#33
Post by Indy510 »
Indy510
#34
Post by Indy510 »
Drove to In-n Out to make Skib jealous on a insomniac thread ... and the car broke down on my way home
Indy510
#35
Post by Indy510 »
It was probably because I had the fan hooked up to a toggle switch, cause it died as soon as I flipped the fan switch. I had to disconnect the MAF to get it to idle and limp home. Everyone said I needed a new MAF, but that didn't fix it. Then I checked for vacuum leaks... nope. So I just took everything apart .. and broke out the cut-off wheel ...:lol:
Indy510
#36
Post by Indy510 »
A new/used ECU fixed the problem .. but when I drove it there was no power. It sounded like an exhaust leak, so I got a OBX S13 header:
but it didn't fit, so I got 2" extensions welded on at a muffler shop:
Indy510
#37
Post by Indy510 »
I finished polishing/shaving the intake:
Indy510
#38
Post by Indy510 »
The wagon still didn't have enough power .... it turned out the spark plug wire firing order was backwards ... :lol:
... but before I figured that out, I had already torn apart the whole wiring harness:
Indy510
#39
Post by Indy510 »
Indy510
#40
Post by Indy510 »
