Holy crap, I've owned this car for 5 years and still haven't gotten it finished.
Well we bought a new house out by Oregon City in late June and moved in on the 4th of July. Nice place has a nice big shop, couple of decent sheds and a bit more than an acre. Been really sucking up my time though, installed a new wood stove, getting the machine tools setup in the shop, building a new workbench, and just lots of misc. house stuff.
Pic is a panorama of the back yard.
New wood stove I installed (pic is right after installation, I moved the pictures off before running it). I've been enjoying having a wood fire going again, we also have a 550gal underground oil tank and oil heater to supplement.
Workbench I built, height and depth is custom set for me, as I find most workbenches to low.
However for Datsun stuff, I'm finally settled for the most part in the new shop so that I could actually work on the car again.
Last weekend the first order of business was to empty all the crap from moving out of it. Second was to make a new list of what needs to be done and to look over the current condition as I really haven't touched it much in the last 2 years.
Well had some time today and did some work on it again.
Got the wiring done for the fuel pumps and the feed line from the tank to the pump done. Also ran the wire under the carpet up to the ECU for the fuel pump. If I can find my flare tool and go pick up some rubber 5/16 fuel injection line I can finish up the fuel system. Turns out the FI line I had was 1/4 or it would have gotten done today. Still trying to figure out where some parts and certain tools are as I haven't completely unpacked everything just yet.
Also installed a rebuilt KA wiring harness I picked up recently, have a #10 ECU modded by JWT to install also which is now just sitting on the floor of the passenger footwell. I'll mount it soon. Relays are already installed as needed, down to basically just a few wires that need to get finished up for the KA harness. Ended up putting a new hole in the firewall for it (has a rubber grommet in the second pic) and running it under the injector rail. I still need to replace the rubber gaskets on the injectors (boxes on the right). I do need to figure out where a couple of the wires go of the KA wiring harness and to clean up the 1200 wiring harness and tie it into the alt and other places.
You can see the harness before installation in the background there. Picture was to help me figure out what I needed to do with the accelerator cable between the 1200 original and the KA cable (I think out of a truck).
