I haven't hooked up the new aluminum radiator I got but I haven't even put water in going to see if it starts before I do all that. Added some fresh fuel tonight which I'm pretty sure is non-ethanol been sitting for a little bit but should be okay pretty sure I filled it up in about November.
got the battery charged tonight so tomorrow I'll put that in see if it fires up and if it does I'll put the new radiator in and get that situated and then just a matter of cleaning up my mess and fixing a few things here and there. Then it's off to the dyno for tuning after I make an appointment they're probably 3 or 4 weeks out right now.
Also need to mount the intercooler on some rubber mounts in the top and put a bottom mount on it but it's roughly in the place it needs to be.
Oh yeah, I need to put the new transmission in. And the box van was running just fine but decided to start having issues starting. Long cranks it appears the fuel pressure is bleeding off after it sits for a bit. Once you get it going it's fine. Don't smell any fuel leaks but that's next thing to check before I decide to drop the tank and fiddle with the fuel pump I just put in about 5 months ago. If I do find it's that I'm putting a line down the tank and going to relocate the fuel pump in line on the frame so I don't have to drop a stupid huge ass box van fuel tank every time. It's rather heavy and unwieldy and we can't really get it high up on our racks at work because the ceiling is too low. Plus its a bitch to maneuver for the drive on rack.
Filling fuel rated hose with Right Stuff makes for great vacuum plugs that don't wear out FYI.
[url=https://postimages.org/]
