Smaller. Better. Slower. Lower..gaver
Re: Smaller. Better. Slower. Lower.
If what ive done this far hasnt got you to canby, its hard to beleive a gasket kit would. Lolololol
Can you go take a bunch of pics for me.... I need to see it.
- Has thanked: 1350 times
- Been thanked: 232 times
Lots of sunny coupes on fb today.... help me fill my void.......
Wat?
Wat?
Oh shit. I hadn't even seen that this got bumped.
My bad.
I don't have a picture of the actual car....BUT...I do want to share this picture of the A10 crossmember. Enjoi.
Also, don't forget about the meat.
http://nwdatsuns.com/viewtopic.php?f=23&t=965
My bad.
The inner pivot points look close.
- Has thanked: 1204 times
Mmmm...bumpsteer.
Giggity.
There is tons of left and right movement with this rack.
If my measurements come out the way I think they will-custom inner and outers and a joint from the column to the rack will make this an easy swap.
Laecaon wrote:What is that rack from?
Hahahahahaha...FR-S. Manual rack. No assist.
Customer came in after slamming a curb. Replaced tons of parts. Cash.
My guess was to avoid totaling the car. Bill was huge.
After the car left, this thing was just sitting outside next to the scrap bin. Yoink!
Looked like a close fit when I saw it. Who knew it would be this close?
Doesn't look close at all... Looks like the pivot points are so far wider than the lca pivots.
Yes. And plus... its a 210. One handed steering all day as it is. But what ever. As long as you dont put square headlights in it I dont care.
Laecaon wrote:Doesn't look close at all... Looks like the pivot points are so far wider than the lca pivots.
Elaborate. I think you just spoiled my game plan.
Lca pivot and balljoint picot should be equal distance/angle to the inner and outer tie rod pivot points.minamize bump steer. That being said, every singel 510 with power steering has an ill fitted rack.
What's the width between LCA pivot points?
