The new 1200 acquisition
Re: The new 1200 acquisition
#101
I have a set of metal engine brackets. They are on an a14 and were in a b210. Would those work ?
Gray
Cars: '74 4dr B210, '71 1200 coupe, 2015 Leaf, 2014 Toyota Sienna, and the 4x4 '97 F150 farm truck.
Has thanked: 18 times
Been thanked: 25 times
#102
Post by Gray »
izzo wrote:I have a set of metal engine brackets. They are on an a14 and were in a b210. Would those work ?
1200 brackets are specific, but thank you. B-keeper said he was going to hook me up with a set. :)
aka Dguy210
#103
No problem yo! Anything i can do to help im glad to
Gray
#104
Post by Gray »
izzo wrote:No problem yo! Anything i can do to help im glad to
:thumbs:
aka Dguy210
Gray
#105
Post by Gray »
Picked up a B210 H150 diff from a sedan today... :D
May be needing a 2mm adapter soon....
aka Dguy210
Has thanked: 2 times
Been thanked: 2 times
#106
Post by RedBanner »
Me too. Morrisun says he has some. Going to hook up with him eventuly...
Has thanked: 1204 times
#107
Gray wrote:May be needing a 2mm adapter soon....
Easy to make. I used a piece of scrap aluminum.
#108
Post by RedBanner »
Indeed. Not hard at all.
Doug has ben telling me just to throw a h165 in it.
But im also realy trying to keep the weight as low as possible.
Gray
#109
Post by Gray »
Yeah I saw the one Bprojects had for like $80 and I'm way too cheap for that. $20-30 would probably be my upper cutoff on buying something I can just make out of some 14 gauge steel or aluminum. I mostly just want to be able to run a B210 driveshaft (which I have several, auto and MT) and have the upgraded rearend for the A14.
I've made an adapter to run the B210 driveshaft with a 1200 flange before (~15 years ago), but it really requires a lathe and a drill press to do it right. The B210 driveshaft is 7mm shorter so you can use a piece of 1/4 plate (~6mm) and rotate the bolts holes out of phase with each other, but if you want the centering hub to line up on both sides it needs to be cut down from a thicker piece of stock say 1/2 or so. I seem to remember starting with a big piece of aluminum roundstock and cutting both centering cones by eye and then drilling the holes but it was a long time ago.
RedBanner wrote:Indeed. Not hard at all.
I was surprised how much heavier the H150 is then the H145, I know they upgraded other parts besides the pumpkin, but honestly I never blew up an H145 with an A14 anyways and I certainly didn't baby them.
I loved to get an H165 for the B210 to put behind the KA. I have an H190 from a 510 wagon but it requires shortening the driveshaft, and supposedly the H165 doesn't. I have a really sweet rebuilt serviceable driveshaft on my 63A now and I'd rather not molest it just to run the KA.
aka Dguy210
Gray
#110
Post by Gray »
Not dead just busy.
:fuu:
Also I have some ideas for some stickers I'd like reproduced at some point. Test piece, still need to make some corrections to the file.
Also the last of some bumper stickers I had made a long time ago, the company has since gone out of business (I trimmed off the ad before using).
Have to go back to work now :(
aka Dguy210
#111
lol. work sucks man. thought there was going to be some super awesome update
Morrisun
#112
Post by Morrisun »
2mm spacers and gaskets-$24.00, yes this is in the wrong forum, but seems appropriate?
These are the gaskets and steel spacer for putting H150 3rd member into a Datsun 1200 H145 axle housing. Parts were made on a programmable cutting table.
#113
This is the perfect spot. You could also make a for sale ad if you wanted :lol:
Gray
#114
Post by Gray »
Morrisun wrote:2mm spacers and gaskets-$20.00, yes this is in the wrong forum, but seems appropriate?
:fyea:
Do want!
Edit: PM'd
aka Dguy210
Gray
#115
Post by Gray »
izzo wrote:lol. work sucks man. thought there was going to be some super awesome update
Okay so here are the super future plans. This is for much later down the road and will require a header of course. Both carbs run but I will probably rebuild and will definitely need to rejet etc... 45 DCOE's are super overkill of course without corresponding work done to the engine :troll:
aka Dguy210
B-keeper
#116
Post by B-keeper »
Gray.......... I have not forgotten you :)
You really do want to lighten the 1200 flywheel.. I used an A12 in my A14 that I had machined down.
I took this info to the machine shop
Gray
#117
Post by Gray »
:D
aka Dguy210
#118
Post by RedBanner »
Nice! Just reminded me to save the flywheel pic from bkeeper also!
#119
Post by 510freak »
Gray wrote:Image
:D
:fyea:
Thats sweet man
#120
That's gotta be kinda rare.
