the red banner
Re: the red banner
Peachy orange.... salmon maybe.
Re: the red banner
lol. wish i could wire shit like that... You use a diagram or just kinda know how or wtf
Re: the red banner
Its call magic Izzo. You wave your hands over it and it happens.
But really its dead simple. You just have to understand how electricity works and bam.
Re: the red banner
I Just wired it. Yeah. Was the first time I wired up a low oil pressure shutoff into the fuel pump curcuit. It was all easy peasy. The hardest part was explaining how the relay worked to my bro lololol
So easy, that it would only complicate things to make a diagram on this scale.
Re: the red banner
Head gasket just showed up... timing cover section damaged...... no deal.
Re: the red banner
And there shop is closed till monday.... god damn it!
So ill get a replacement like.... Wednesday.... fuck. That sucks.
Re: the red banner
Zx struts. Brake brakets cut off,
Willwood, caliper adapters.
Uses zx disk and hub.
Sparkly graphite paint.
Re: the red banner
Re: the red banner
Making rainbows in the other race car.
I can never bring myself to cut the tach wires.... so bunches extra hidden in the dash
I know it looks like alot of green, all the fuel pump related wires are all green and the relay has 4 conections. , cause the lights are grean. And so the theme continues thru out.
Re: the red banner
With very little modding at all I got my 13s to fit over the zx/wilwood brakes.
It was so close that I got some 2mm spacers, but wont need them after all.
Gotta throw the rotors on the brake lathe tomarow. They where brand new but got some surface rust from sitting in my trunk all winter.
Clears the strut tube by a mile and then some.
Got almost an inch to the berral, the face was what was close.
Most zero ofset wheels I tried just scrubbed the face of the caliper. 14s and 15s too. Wouldnt have taken much spacer, but if you can run without them thats best.
Re: the red banner
Well aint that some shit lol
Re: the red banner
hahaha.
Love your work dude. Seriously.
PS, I have some of those conical (sp?) spacers if you need some. They came with those wheels i bought out of bend....
Re: the red banner
Re: the red banner
Actually it gets worse with the Tie rod. The Tie rod with RCAs wont go inside a 15" wheel. Not sure without.
Re: the red banner
This is with 1" rca spacers (actualy 1.25 but I bought them as 1 ")
tie rod clears, but it is close. It is actualy right even with the wheel bead. I need to mount it all up without the spring intalled and go thru the full range of motion to check all clearences. I realy kinda wanna bend my steering knuckles anyways. I know I have the rcas, so I bolted em up.... but maybe ill do the knuckles also/instead.
Re: the red banner
So. Cut the shit out of my strut towers, stitch welded one side but it started getting windy and I couldnt block it. Going to have to grind some uglies back out.
Then I lowered the perches on these truts to match the new ones, just to see how low it would be.
It should actualy sit 2.25 inches lower than this, 5.75 right now.
Re: the red banner
Had myself a good hard cry today.
Current plans are to weep again about it tomarow, then pop the other side open. And cry some more....
