Page 9 of 19
Posted: Mon Jul 25, 2016 8:49 pm
by Indy510
I sanded all the metal with 80 grit, before the RAGE ultra body filler ... any coarser grit sandpaper will need filler to hide the scratches:
Posted: Mon Jul 25, 2016 8:54 pm
by Indy510
I modified the gas door to fit a 510 gas door lock ... because a 160j has a lock instead of the 710 pull handle:
Posted: Mon Jul 25, 2016 9:08 pm
Someone working on their Datsun, keep going at this speed and your going to be done in no time.
Problem is that once you are done, there will be no new photos to look at, so take your time.
Posted: Mon Jul 25, 2016 9:21 pm
If you are on Facebook, you have already seen into the future. Car is looking real good.
Posted: Mon Jul 25, 2016 10:15 pm
by Indy510
Posted: Mon Jul 25, 2016 10:23 pm
by Indy510
Posted: Mon Jul 25, 2016 10:26 pm
by Indy510
Always read the Data sheets for paint and body filler .... This self etching primer says it can go over fully cured body filler, but DO NOT put it under body filler:
I still tried to avoid getting it on the biggest filler spots:
Posted: Mon Jul 25, 2016 10:32 pm
by Indy510
Then high build / surfacer primer: ... cause it doesn't stick good enough to bare metal, but it is good on body filler:
Posted: Mon Jul 25, 2016 10:59 pm
by Indy510
Posted: Mon Jul 25, 2016 11:06 pm
by Indy510
Posted: Mon Jul 25, 2016 11:15 pm
by Indy510
I found a 12" wide ,semi-flexible "triple knife edge" drywall spreader, for $1.99, that's great for spreading body filler:
Then roughed it out with a 1/4 sheet electric block sander ... and finished with a 1/2 sheet sanding block, by hand:
Posted: Mon Jul 25, 2016 11:20 pm
by Indy510
The trunk was almost perfect already:
Posted: Mon Jul 25, 2016 11:22 pm
by Indy510
Posted: Mon Jul 25, 2016 11:27 pm
by Indy510
Posted: Mon Jul 25, 2016 11:29 pm
by Indy510
Yes, that upside-down bucket is so I can drive it ...
Posted: Tue Jul 26, 2016 5:58 am
Stuff like this is why I should be on fb.
Ah bullshit, you'll fill me in eventually. I'm slow anyway.
Posted: Tue Jul 26, 2016 6:08 am
by Ni10
Posted: Tue Jul 26, 2016 9:18 am
by Indy510
Taterhead wrote:Stuff like this is why I should be on fb.
No you shouldn't ... it's horrible, and I have only posted 3 times in 2 years ... my 60 friends got to see one picture of the color, 2 days ago.
Posted: Tue Jul 26, 2016 10:35 am
LOL
Right! I rarely see an indy post.
Posted: Tue Jul 26, 2016 1:51 pm
I one of 60!!! yay.
