Page 9 of 39
Re: The "Retired" 510
Posted: Fri Dec 16, 2016 6:01 pm
Does your 4-speed have a big steel pan on the bottom (510/521 style) or a small steel cover on the top with 6 bolts just ahead of the shifter (240Z style)?
Posted: Fri Dec 16, 2016 6:37 pm
by noflers
It's the 510 style.
Posted: Fri Dec 16, 2016 6:50 pm
Sorry, shifter won't work on the 5-speed.
Posted: Wed Dec 21, 2016 3:30 pm
by noflers
So I've got all these new parts here, but none of the bolts. I should be picking them up Friday from the dealership, including the starter, bell housing, flywheel, pressure plate, and valve cover bolts. I wanted a throttle cable too, but they want $95 for it!
Until then, I'm stuck. I guess I could pull my motor and drop it in the 620 but I was hoping my buddy would get the engine bay cleaned up first. Slow bastard he is.
Posted: Thu Dec 22, 2016 12:31 am
by Indy510
I just got a brand new Pioneer 240sx throttle cable, for a 1991 KA24DE, off rock auto for $32 ... and there's even %5 off discount codes in the Ratsun classified "discussion" forum
the cable is listed under "interior" on rock auto, and it looks really good .... I can take some pics if you want
Posted: Thu Dec 22, 2016 6:03 am
What are your crossmember plans?
Posted: Thu Dec 22, 2016 6:47 am
by noflers
I saw those throttle cables, but wasn't sure about quality. I think I'll order one now.
I plan on the standard cross member flip. I'd rather not, but unless I can find one already flipped, or a custom pan/sway bar at a reasonable price, it's all I can do. I really just need someone to cut it straight for me, as I can weld it myself.
Posted: Fri Dec 23, 2016 7:51 am
by noflers
How did you attach the cable to your pedal?
Posted: Fri Dec 23, 2016 8:48 am
by Indy510
I'm using a 1991 240sx stock gas pedal ... it will take a little modification to fit a 510, but it would probably work. I got it for $30 shipped off ebay. My old cable was cut and threaded through a hole drilled in the top of the stock pedal, but the cable got frayed and turned into 100 loose strands.
Posted: Fri Dec 23, 2016 6:42 pm
Don't mind me, just came by to check out the awesome car.
Posted: Sat Dec 24, 2016 1:00 am
Get creative and cut it with an angle grinder. Just dont forget to tack the ends of the crossmember together to keep their alignment.
And nice tip on the cable Indy! I need one too.
Posted: Sat Dec 24, 2016 6:28 am
by noflers
I shouldn't be worried about making sure both cuts are symmetrical?
At first I was mad I had to spend $40 on a Helicoil kit, then I was actually glad I did because I've had to use three inserts so far, but then I was mad again when I remembered the PO stripped the bolt holes in the first place. At least they were all the same size (M6x1.0), so I only had to buy the one kit.
NOTE: Heli Coils are freakin' handy and easy to use, I think I'll strip more bolts!
I've still just been bolting things back onto the motor, I should have a finished picture later, just need to get the clutch on. Found one of the mounting ears on the starter is broken off too, so I'll need one of those... So far I've replaced, the rear main oil seal, CLEANED, removed upper timing chain guides, replaced most of the engine sensors, single belt/PS pump delete mod, CLEANED, new flywheel with new bolts, EGR delete, liquid gasket everywhere it needs to be. Oh, and I also cleaned and replaced the seals on the transmission.
P.S: New flywheel didn't come with dowel pins, and the motor didn't come with a flywheel so I can't take them off that. Most people will say they aren't critical, but what do you guys think? Bolt the clutch on, or wait and make the trek to the dealer again?
Posted: Sat Dec 24, 2016 12:02 pm
I like the dowel pins...
As far as crossmember cutting. You can make it fairly straight. Use a laser guide to draw straight lines to cut on. Use a tape measure to make it fairly parallel.
If you mess it up too badly, just box in the end pieces and run some DOM in place of the cut out piece.
Posted: Sat Dec 24, 2016 12:06 pm
by noflers
Do you know the wall thickness of the crossmember material by chance?
Posted: Sat Dec 24, 2016 12:45 pm
Page 13 of this:
Updated crossmembers have a thicker bottom plate as explained in that pdf. I would imagine the rest of the crossmember is the same as the old bottom thickness.
Posted: Sat Dec 24, 2016 12:48 pm
And I suppose it would be good to share where I got that from...
https://drive.google.com/drive/folders/ ... sp=sharing
Posted: Sat Dec 24, 2016 2:34 pm
by noflers
Great info, thanks.
Here's this:
Still waiting on bellhousing bolts so I can stick the trans and motor together...
Btw, Subaru exhaust manifold studs work great for the KA!
Posted: Sat Dec 24, 2016 2:53 pm
Since Subi is Fuji Heavy Industries which Nissan used to own a big part of, there are a lot of things that make too much sense.
Posted: Sat Dec 24, 2016 2:58 pm
by noflers
You know, now that I think about it, the exhaust downpipe flange is the exact same too
Posted: Sat Dec 24, 2016 4:07 pm
Well, huh. Never even considered the crossover with Fuji.
