Page 9 of 37
Posted: Thu Sep 26, 2013 12:21 pm
what what in the butt
If i part out this hardbody ill make you a deal on the front end, yo. big brake upgrade!
Posted: Thu Sep 26, 2013 12:28 pm
by Eagle_Adam
im good.....
i just want 4 wheel discs and my KA done.......
and then for realz, i dont wanna fuck with the truck anymore till paint/boost
Posted: Thu Sep 26, 2013 2:10 pm
by Eagle_Adam
boom!
timing kit and gasket kit are here!
time to tear into the motor
Posted: Fri Sep 27, 2013 4:26 pm
by devilsbullet
doesn't have a part number on it that I can find, Its a carter, the only 280z carter fuel pump I found looks kinda like it but is slightly different. I can send you a picture of it if you want.
Posted: Sat Sep 28, 2013 10:00 am
the hardbody stuff is a straight swap over man.... Instant big brakes, really easy. Four wheel discs will be good, but big front brakes with turbo KA would be better, jus sayin. Then you can later on do the belltech 2 drop spindles if you wanted. (can now anyways lol)
Posted: Mon Sep 30, 2013 6:31 am
izzo wrote:what what in the butt
Posted: Mon Sep 30, 2013 7:59 am
by Eagle_Adam
looks like a made a trade!!!!
these should be running behind my titans before the swap is done!
Posted: Mon Sep 30, 2013 9:19 am
I'm sorry did you say something? i was to busy staring at your brakes jerking off.
Posted: Mon Sep 30, 2013 9:23 am
by Eagle_Adam
nothing important izzo, carry on
Posted: Mon Sep 30, 2013 9:36 am
Posted: Mon Sep 30, 2013 9:55 am
by Eagle_Adam
a little less exciting but still crucial
new headbolts
Posted: Mon Sep 30, 2013 10:10 am
Aww man, no ARP head bolts?
Posted: Mon Sep 30, 2013 10:37 am
by Eagle_Adam
no, not this time around
Posted: Tue Oct 01, 2013 11:22 am
by Eagle_Adam
EGR delete plate came in today
Posted: Tue Oct 01, 2013 11:40 am
EGR is for pussies anyways. I'll like my unburnt fuel out the exhaust, it's like coffee in the morning.
Posted: Thu Oct 03, 2013 9:51 pm
by Converted_to_datsun
izzo wrote:the hardbody stuff is a straight swap over man.... Instant big brakes, really easy. Four wheel discs will be good, but big front brakes with turbo KA would be better, jus sayin. Then you can later on do the belltech 2 drop spindles if you wanted. (can now anyways lol)
Do the hardbody breaks clear with 14's? If they do it sounds tempting
Posted: Fri Oct 04, 2013 8:57 am
Converted_to_datsun wrote:izzo wrote:the hardbody stuff is a straight swap over man.... Instant big brakes, really easy. Four wheel discs will be good, but big front brakes with turbo KA would be better, jus sayin. Then you can later on do the belltech 2 drop spindles if you wanted. (can now anyways lol)
I think so. Isn't the hardbody stock 14" rims? I put the hardbody up for part out, someone snagged the front brake setup already
Posted: Fri Oct 04, 2013 9:13 am
i did a little research and you need 15's to clear, too bad. Lol i love my 14's so i guess i'll stick with single piston calipers
Posted: Fri Oct 04, 2013 9:45 am
I don't think that's correct man. the stock hardbody rim is 14 inches.... Unless it's just aftermarket rims that don't work
Posted: Fri Oct 04, 2013 8:59 pm
The stock Hardbody rims are offset around the calipers to fit them.
Dual piston HB clappers won't fit most 14" wheels. And some 15s don't work either.
Offset is key.
