Page 10 of 11
Posted: Tue Jan 07, 2020 2:14 pm
by Indy510
While changing the wiper cowl area, I chopped the front of the roof a 1/2" to get rid of the reverse rake roof line. I still hate the c-pillars, but that will get fixed later:
Then I took the body back off:
Posted: Tue Jan 07, 2020 2:22 pm
by Indy510
Posted: Tue Jan 07, 2020 2:25 pm
by Indy510
Then I made some wheel tubs that connect the 510 skin to the miata-outline frame:
Posted: Tue Jan 07, 2020 2:30 pm
by Indy510
Below the doors is a 1.5x0.75" square tube rocker panel, which helped make the side of the car straight. Then I used an on-sale Eastwood dimple die set to make this filler piece:
Posted: Tue Jan 07, 2020 2:35 pm
by Indy510
The old trunk lid I made was never going to look right, so I traded some of my last Datsun parts for another trunk lid, with a poorly shaved lock hole:
Posted: Tue Jan 07, 2020 2:40 pm
by Indy510
This time, I clamped the trunk to my welding table and made sure everything was flat when I welded it:
Posted: Tue Jan 07, 2020 2:43 pm
by Indy510
Now that I had a trunk with the stock shape and curve, I could start building the widened futo-fab window frame:
Posted: Tue Jan 07, 2020 2:48 pm
by Indy510
These two pieces started out as a flat angle bend... then I shrunk them both ways until they fit the shape of the window frame:
More dimples... I should have used a smaller hole saw, but all I had was the 1-1/2" one I got for the roll cage:
Posted: Tue Jan 07, 2020 2:53 pm
by Indy510
And it fits:
Posted: Tue Jan 07, 2020 4:16 pm
That is the most positive rep I ever gave anyone in my life, talk about customizing, you building a whole new car from scratch almost.
I might have messed up and hit what I thought was positive rep but it may have turned into negative rep, sorry I didn't mean to do that.
Posted: Tue Jan 07, 2020 4:43 pm
This car is still ridiculous and I still really, really like it. Your fab work has really improved over the years. Great work!
Posted: Fri Jan 10, 2020 10:59 am
Posted: Thu Feb 06, 2020 11:56 pm
by Indy510
Haha. Thanks everyone.
I cut off the c-pillars last month. They were never going to look 'right'. I think my mistake last time was not having all the body panels mocked up. So, this time everything is still on the Miata:
Posted: Fri Feb 07, 2020 12:01 am
by Indy510
I started with a lightly shrunk 20ag angle at the top, to match the roof's curve:
Posted: Fri Feb 07, 2020 12:03 am
by Indy510
It still didn't look 'right', so I leaned the other pillar even farther forward:
Posted: Fri Feb 07, 2020 12:10 am
by Indy510
I basically finished both sides, but each pillar was 5 separate pieces of metal and had almost no patina left. So, I made a template off the best one:
Posted: Fri Feb 07, 2020 12:16 am
by Indy510
Posted: Fri Feb 07, 2020 12:17 am
by Indy510
The first two bends were easy on my super cheap folding brake, but the reverse bend was done clamped to a table -- using a soft hammer:
Posted: Fri Feb 07, 2020 12:20 am
by Indy510
Then I used the same hammer and a sandbag to curve to the flat part:
Posted: Fri Feb 07, 2020 12:25 am
by Indy510
But I got carried away English wheeling the hammer marks and made a compound curve where there shouldn't be one:
