Page 10 of 46
Posted: Tue Apr 01, 2014 3:40 pm
by draker
izzo wrote:I'm always waiting on this
I hear you there buddy.
Posted: Tue Apr 01, 2014 7:05 pm
by draker
Good day at the yard this weekend.
This is temporary.. I've got better plans.
Window visors
Posted: Tue Apr 01, 2014 9:10 pm
that is agood day. can always drop the wheel and use the hub on a grant wheel
i want something mahogany in my ride.
Posted: Tue Apr 01, 2014 9:24 pm
by draker
izzo wrote:that is agood day. can always drop the wheel and use the hub on a grant wheel
I'm definitely thinking something woodgrain. We'll see when I get to the interior.
Posted: Tue Apr 01, 2014 9:38 pm
by Skeletonbonez
Someone say woodgrain..
Posted: Sun Apr 06, 2014 9:44 pm
by draker
Today was a long day..
Heres what I got done:
Installed radiator
Installed bought and installed new fan belt
Successfully deleted the rest of the air injection system and plugged the rest of the holes
Installed driveline
Installed Exhaust
Filled tranny with fluid (stinky shit...)
Hooked up parking brake again
Installed new 200sx slave cylinder and bled.
Filled engine and cooling system.
Modded trans access plate and mounted
After fiddling with the starter for a bit... it fired right up!! That was my goal for the weekend.
A bonus, I was able to successfully shift through all the gears in the dogleg. Everything was smooth with no load on it. I'm still waiting for the tranny crossmember from T3.
Next up.. more brake bleeding.
Pretty stoked!!!
Posted: Mon Apr 07, 2014 4:15 am
Almost a driver!
Posted: Mon Apr 07, 2014 10:29 am
wow man that is quite the list!
Trans fluid is stinky shit. Cost me 20 bucks for two things of GL4 at napa. not cheap either lol.
Posted: Mon Apr 07, 2014 4:19 pm
by draker
izzo wrote:wow man that is quite the list!
I put some cheaper crap in there. GL4.. but I'm just going to run it a few more times while it's in the air and drain it out. Will probably run MT-90 or something. Gotta read the fine print on it first.
Posted: Mon Apr 07, 2014 9:05 pm
by draker
Got a little more work done today.
Installed new points (I had them sitting around before I bought the EL dizzy.)
Installed new cap, rotors, wires
Gapped plugs
Engine was still barely running.. and it was running like shit.
Looks like cylinder 3 was not firing.. and the spark plugs show it's running really rich. I've confirmed I've got spark.. plug looks wet. Next up, compression test again. Previous numbers were okay. I've already adjusted the valves.
Hoping for the best!
Posted: Mon Apr 07, 2014 9:10 pm
by draker
Pull the original compression numbers from before I ever started the engine.
1. 90
2. 135
3. 60
4. 155
I gotta say, #3 is a little discouraging. But if I recall after getting it running those numbers improved. Let me see if I can find them
Posted: Mon Apr 07, 2014 9:12 pm
by draker
Nope, I didn't. I'll compression test it again tomorrow. Fingers crossed.
Posted: Tue Apr 08, 2014 9:28 am
ah hell even gl5 ran a few times just in the air won't hurt anything. It's over time that the detergents in gl5 wear down your brass in the tranny. But good on you for using even cheap gl4 lol.
PS, you probably know. But if it says GL4 & gl5 compatible, you don't want to use it long term. GL4 only
Sta-lube for the win!
Posted: Tue Apr 08, 2014 3:15 pm
by draker
izzo wrote:ah hell even gl5 ran a few times just in the air won't hurt anything. It's over time that the detergents in gl5 wear down your brass in the tranny. But good on you for using even cheap gl4 lol.
Yeah, I did some research before commiting. I bought some valvoline GL4. Not sure if it was a mix, but it was reported by the manufacture to no have the activated sulfates in it that are not safe for yellow metals. Also reported their GL5 does not use these activated sulfates either.
Regardless of all that, I'm just flushing the trans. It was open to the air for a long time. No rust.. and it was pretty clean. But nothing like a solid flush.
Posted: Tue Apr 08, 2014 7:19 pm
by draker
Compression numbers from today:
0-60
150
170
170
The weird part is that #3 was the one not firing. Anyway, leakdown showed 100% out the exhaust.
I popped the lid, found the lash pad popped out. Haven't fixed it yet.
Once I put it back in, it's time to figure out why #3 wasn't firing. Compression is good... spark was good, fuel is fine... spark at wrong time?
Posted: Wed Apr 09, 2014 4:48 am
Vacuum leak on #3?
Posted: Wed Apr 09, 2014 8:13 pm
by draker
Adjusted all valves again and compression tested:
170
150
165
160
Not fantastic... but much better!
Posted: Wed Apr 09, 2014 8:18 pm
by Skeletonbonez
havent looked at your thread in a while. holy shit man... Kickin' it in high gear for sure! Wooo!!
Posted: Fri Apr 11, 2014 10:09 pm
by draker
Posted: Sat Apr 12, 2014 8:27 am
That seat looks comfortable. I'm jelly lol. I have the most uncomfortable seats ever in my truck
