Page 10 of 27
Posted: Fri Oct 17, 2014 1:03 pm
Truck hit 150k miles!
Posted: Wed Oct 29, 2014 7:15 pm
I heard a noise. I think i know what it is. And I don't wanna fix it :| (ok well maybe I do with my new tools. Oh yeah, I got new tools. I need to pose those) haha.
Posted: Tue Nov 04, 2014 2:49 pm
well shit. I can't figure out what's making a clank noise
I thought it was the upper ball joint. which was really bad. I replaced it, took it for a spin. Still makes the noise. It's sketchy. Seems like when the suspension extends like coming up over top of a hill or certain whoops in the road, is when it does it. I pried on stuff and can't find anything that is wiggling. All the bushings look fine. Wiggled everything.. can't figure out where the clank is coming from. Bottom ball joint has no play in it.
Posted: Tue Nov 04, 2014 5:27 pm
Shock mount?
Posted: Tue Nov 04, 2014 6:18 pm
Well. There is a noise up front and in the rear. The ball joint was def failing. When I turned hard right or left you could hear it creaking really bad. I think the louder clunk has went away. I did check the shock, it seems fine. Tho I will replace to be sure. The bushings are weather cracked but still all there. Maybe it's the bump stop hitting? There is not much room from the upper a-arm to the bump stop for downward travel.
So will replace front shocks soon. Will also investigate the rear. Maybe it's something back there.
Pictars!
Posted: Tue Nov 04, 2014 6:55 pm
Ah shit, it's a 4wd, it could be a lot of things, you sure both hubs are unlocked?
Posted: Tue Nov 04, 2014 7:39 pm
Yeah, I don't think it has anything to do with drive drain. Thinking suspension...
Posted: Wed Nov 05, 2014 1:42 pm
That's what I was thinking too. Something with the front drive axles. CV joints?…
Posted: Wed Nov 05, 2014 7:42 pm
Don't think so. It's a clunk.. Instead of a constant ticking like an axle usually does. seemed nice and tight. Shrug.
Haven't figured it out yet.
Posted: Thu Nov 06, 2014 1:38 am
Check for recent contact of axle to LCA, UCA to bump stops, tie rod to sway bar, UCA to shock body. Maybe its the sway bar...
Posted: Thu Nov 06, 2014 6:25 pm
Oh yeah I have.
Checked for anything I could. Rub marks, clean spots etc. I can't find anything.
Posted: Thu Nov 06, 2014 6:47 pm
by BLUE
izzo » Sat Sep 06, 2014 11:52 pm wrote:Noise is gone. Guess I shouldn't leave a soda can against the 4X4 shifter hahaha. :cha:
:rofl: awesome ! :thumbs:
izzo wrote:Don't think so. It's a clunk.. Instead of a constant ticking like an axle usually does. seemed nice and tight. Shrug.
Posted: Thu Nov 06, 2014 7:23 pm
lol. that was a vibration, the popcan.
This is clearly a noise coming from up on front driver wheel area. Bearings seem tight too, no wobble.
Posted: Thu Nov 06, 2014 7:31 pm
Does braking seem to affect your noise?
I chased a noise on a Chrysler minivan for a while. Turned out to be worn out caliper slide bushings. Caliper would clunk on bumps.
Posted: Thu Nov 06, 2014 7:33 pm
It seems like its when I turn left, or come off a bump. Turning left makes the suspension extend, same with when im coming off a bump or over a hill onto a flat spot. Ill wiggle the brakes around a bit and check on them too. Probably be a saturday project. I will take some pics of everything. See if maybe can spot something I'm missing.
Posted: Tue Nov 18, 2014 10:37 am
Well. It is still there at random. I don't think I've noticed it as much lately. not sure, been to much shit giong on lately.
I need to get that patch sent to K-trip. Sorry for the patch delay :(
So up next on my shits... My garage. I need to get down to the DMV this week and get that black truck titled and gone. I sent an offer on a trade. My quad for a 620 king cab in portland, it's an automatic and has a canopy and roof rack.... We'll see what happens with that.
Anyways, my garage!! I am in the process of planning it out. I am getting my blueprints drawn up for my work bench. I may redo it with some changes, but for now the basics of it is complete and measurements are done. 2x4s, 4x4s. the 4x4s will be the legs, the 2x4s will be the beams. I will probably be doing 12 on center across the table part with 2x4s. I am going to do one sheet of 3/4 plywood for the table top. I have not decided what route I want to take from there. I do know I want to throw another 3/4" piece on top. The route I will take is either... Just screw it down to the bottom piece, and have it replaceable. Or, coat it with some thick ass laquer or what not to make it shiny and durable for years to come.... It wouldn't get oil soaked that way and last longer I believe. Jury is still out on that one.
It will have a back on it. At first I was going to build an enclosed cupboard area. But, I am re-thinking the idea. I may just leave it as an open shelf. It will make the work bench not quite so high. It will still hold the same shit and maybe even a little more. and then I can easily move it out should I ever move... The height it is now, It would be a real bear to get out as it wouldn't clear the garage door. By leaving it open, and still building at least the shelf. I still get my storage and I get a spot to hang two 3' lights.
This is just my first design. I may change it and scrap the whole idea. I have been reading like a mad man and looking at threads over at Garage Journal. I like a lot of ideas there. I may do pegboard for a back just to have some extra hanging space for tools I use a lot or what not. I may also change up the bottom design and implement a few bottom roller tool cabinets. I just don't know yet.
For the cost of this. Right now, not including the lights. It should be a cheap-ish build. I haven't counted exactly how many boards I will need. But I'm ballparking 100 bucks. Maybe just over. Seems like a good price for a work table. I was offered one for free two weeks ago. But the problem is, it was in portland and I am here. I just couldn't get down there when they wanted it gone.
Obviously this first rough draft design isn't done lol. Doesn't show the 4x4s going up the back side, cross support on the table part blah blah..
Posted: Sat Nov 22, 2014 7:01 pm
Adding to the garage!
I made a wish list for my Bday and gave it to the GF. I have more tools on the way :D Bday is in 7 days!
Thanks Micro for picking this up for me. Got this cool deal. hoping to get MORE. If anyone has these or see them on the cheap for sale, please let me know...
That one is 13x14x30
Posted: Sat Nov 22, 2014 7:08 pm
Nice snag!
Posted: Sat Nov 22, 2014 7:25 pm
Thanks man!
I thought it was a good deal at 40 bones.
Posted: Tue Nov 25, 2014 10:12 am
On the shopping list
Drill Press
Bench Grinder
Dimple Dies
Press Brake
Build work benches
Shop Lights
Talking to a buddy of mine. Need to hurry up and get that pos black truck out of there... We are gonna start turning cycles out of my garage. nothing major, no schedules... just find cheap shit at our leisure and sell things for a few extra bucks.
There's a lot of good deals on CL. Super nice road bikes for 250 bucks. Ran when parked 3 years ago blah blah... Some polishing, maybe replaced a few odds and ends.. Then list it for a grand and let it sit tell it sells. Like I said. nothing major, nothing to support ourselves on so there is no pressure... just make a few extra bucks here and there.
Road bikes, dirt bikes, quads... Doesn't matter... Just stuff we can find cheap and flip.
