Page 2 of 4
Re: 79 Datsun 620 project
Posted: Tue Nov 24, 2015 6:16 am
The wheels look good either way.
Posted: Tue Nov 24, 2015 7:11 am
by Ni10
Posted: Tue Nov 24, 2015 9:49 am
by djmccall74
i plan on putting the paintable bedliner on.
good thought on the tinted windows. got a buddy who does that for a living. think i'll hit him up and see what it'll run me.
Posted: Tue Nov 24, 2015 9:59 am
by Ni10
djmccall74 » Tue Nov 24, 2015 10:49 am wrote:i plan on putting the paintable bedliner on.
I'd wait on making a decision on the wheels until you do get the windows tinted, they might look good as they are.
just a thought on the wheels, wonder what the wheels would look like with a few 1/16" Kawasaki green pin stripping on the outer edge to give them some depth and to break up the black some. Hmmmmmmmmmmm
Posted: Tue Nov 24, 2015 7:08 pm
by yello620
Personal opinion here..
I think that nothing is going to help "those" wheels. They are just too wide, sticking out too far to look good.
Reminds me of the old video game "FROGGER"
Posted: Tue Nov 24, 2015 9:12 pm
MMMM~!!!!!!
Dang man. Get a professional photoshoot done with this thing.
Posted: Wed Nov 25, 2015 7:26 pm
by djmccall74
been slow this week, so had more time to spend on the hulk....
start of side view mirrors, door handle / lock, and chin
new steering wheel, steering column, and door panels redone, dash needs to be refinished and seats dyed black:
exterior almost complete. will finish up the bedliner this week and start on heater core. the whole point of this was to have something i could drive in bad weather. i didn't want to drive my other car in poor conditions, so this thing must produce good heat!
Posted: Wed Nov 25, 2015 7:30 pm
by djmccall74
yello620 » Tue Nov 24, 2015 11:08 pm wrote:Personal opinion here..
personally, i like the wheels.
and that is why i love opinions. thank you for sharing yours!
and i LOVED the game frogger when i was a kid. funny how that game is STILL relevant today...
Posted: Wed Nov 25, 2015 8:05 pm
by draker
color the tailgate letters?
There is a guy that can get you the art and you can take it to any vinyl shop to have them made.
Posted: Wed Nov 25, 2015 10:09 pm
Needs less poke and a little more meat.
I really like the black accents with the bright green paint.
Posted: Thu Nov 26, 2015 4:28 am
by djmccall74
i found a guy who does the vinyls in fla. ordered them earlier this week and they should be on the way. flat black.
i like the idea of the green pinstripe around the wheels (had that on a previous ninja i owned), but going to hold off until the bed liner and tint are done before making any adjustments. i agree that it should break up the black on the wheel from the tire. thanks for the suggestion!
i've owned several ninja's over the years, and is where i got the idea for the theme of the truck. i've even thought about putting a flying K on it somewhere (mud flaps maybe). shrugs.
Posted: Thu Nov 26, 2015 2:06 pm
by djmccall74
happy Turkey day everyone! progress while my turkey was baking in the oven. it was a beautiful 63 degrees, sunny with no clouds today here in good ol' south ga so my son and i tore out the heater core. found a few "issues":
1) water flow valve was stuck shut
2) the cable that moves the water valve wouldn't slide the valve open/shut even if the valve wasn't stuck
3) heater core "radiator" was nasty as all get out
to fix i did the following:
1) soaked in solvent and cleaned. then sprayed with lubricant
2) sprayed with lubricant down the sleeve
3) cleaned out the heater core with pressure washer and high pressure air
Posted: Thu Nov 26, 2015 3:57 pm
If I was there, I would probably have re oringed the valve. When I redid my heater core, I also refoamed the box.
Posted: Fri Nov 27, 2015 7:17 am
by yello620
FYI: that heater valve was still available new from the dealer just a few years ago for under $20 IIRC.
Truck is looking great.
Posted: Fri Nov 27, 2015 5:30 pm
by djmccall74
i thought about ripping into it, but it seemed to be in good working condition after cleaning it up real good.
so far, it seems to be working well. i filled the radiator to about 80% after doing some research/reading. hopefully this will produce enough heat in the cabin to keep me warm back and forth to work.
Posted: Fri Nov 27, 2015 5:37 pm
I would fill your radiator full the way it's supposed to be, if your having issues getting up to temp, then the thermostat is bad, or you don't have one.
When I am going to drive in really cool temps(below 20 degrees), sometimes I put a small piece of card board in front of the radiator that covers a third to half of it, that keeps the radiator warmer when really cold outside.
Posted: Sat Nov 28, 2015 1:17 pm
X2 on the cardboard in cold weather. I cover half in the winter months.
Posted: Sat Nov 28, 2015 6:25 pm
by djmccall74
Posted: Mon Nov 30, 2015 5:45 pm
by K_trip
Looking Good!
Just a suggestion - when you touch up the bed, coat the areas covered when the tailgate is up. Since they're not green (
they look primer gray), covering them in black would be a nice touch ... unless you are going to paint them green to match the rest of the truck. At least the door jams are green.
Posted: Mon Nov 30, 2015 8:48 pm
620 looks great!
