Page 2 of 37
Posted: Thu Jul 11, 2013 8:38 am
by Eagle_Adam
lol, its nice to not HAVE to work on the truck to be able to make it to work the next morning
Posted: Sun Jul 14, 2013 3:58 pm
by BLUE
Hotwheels datto truck with the GREEN wheels !!!! Woot woot !
Keep on keeping on... Eagle_Adam
Posted: Wed Jul 17, 2013 10:37 am
by Eagle_Adam
will do BLUE!!!!
lost an alt bolt on the way home.......... so i replaced it and went to work on the goon
Posted: Thu Jul 18, 2013 8:46 am
by Eagle_Adam
always nice to wrap up the little things!
Got some time last night to check out the breaks, ended up just needing to flush the system with new fluids.
Huge thanx to Banner for coming by to help on the truck and the goon last night, couldn't have done it without you man. Just plain feeling sick as a dog and have felt like this since monday
long story short, your breaks wont work very well if you have rusty water in your lines, or if you break fluid is black...........
All betterz now
Posted: Mon Jul 22, 2013 12:14 pm
by Eagle_Adam
since the trucks breaks were back up to par, i took the dogs with me to a friends new house for a cleaning party
princess LOVES the back of the truck
Posted: Mon Jul 22, 2013 12:43 pm
by RedBanner
Glad I could help, and thank you for yours! And filling my tank with premium!
Posted: Mon Jul 22, 2013 12:46 pm
by Eagle_Adam
help goes both ways man, some people forget that
Posted: Tue Jul 30, 2013 1:18 pm
by Eagle_Adam
some times i wonder who/what i was in a previous life..... cus with my luck i swear i used to be a shady mechanic :/
Ok, could deff use a hand with this one
a week or so ago i bled the breaks on my truck with RedBanner cus they felt squish and if i hit em hard they would go to the floor.
I thought all was well, but today im right back to where i was before but worse.....
The breaks "work" just not very well IMO
Check the fluid levels they are good,
looked for leaks - none to be found
checked the rear cylinders and the front calipers... both look good to me
Why the fuck did my brakes just get squishy again
And before anybody says it banner and I flushed every once of old fluid out of the lines previously
Posted: Tue Jul 30, 2013 1:44 pm
by levigideon
Is the brake master good? When I first got the 210, the brakes were squishy if I didn't pump them a few times. I ended up replacing the master and everything then they worked great. Same thing was the case on Zach's 620.
Posted: Tue Jul 30, 2013 1:58 pm
by Eagle_Adam
ive never replaced it, came with the truck
Posted: Tue Jul 30, 2013 2:41 pm
I think it's your master, also. I have issue with mine, but a little different.
If I hit the brakes on mine, they are right there at the top.. and I can pump them and they are fine too. but if i rest my foot or barely apply pressure it will hit the floor. I think the rubber plunger is falling apart causing fluid to go past. I know you bled the shit out of them, but maybe grab one more big bottle of dot 3 and give it one more shot before replacing the master.
Posted: Tue Jul 30, 2013 2:51 pm
by Farmer Joe
does yours have the Load Sensing Valve?
i have one on mine still and ive given up trying to get good brakes. i can never bleed that unit, and i end up with shit brakes again..
the next chance i get im takin the shit off mine, and doing a normal front for front, back for back system..
just seeing if it could be a thing to check..
Posted: Tue Jul 30, 2013 3:00 pm
by Eagle_Adam
i fucking hate changing MC's!!!!!!!!!!!!!!!!!!!!!!!
Posted: Tue Jul 30, 2013 7:59 pm
by Eagle_Adam
I don't think it's air In the system, but I've been wrong before
Been talkn to Bonvo and his idea of the piston in the MC getting stuck or not returning all the way matches up with what I'm experiencing. Off to go test the theory
Posted: Wed Jul 31, 2013 4:11 pm
by Eagle_Adam
Muahahhahah.......
Who has two thumbs and just dropped their truck off for new exhaust?
This guy
Posted: Wed Jul 31, 2013 4:37 pm
woot!
Posted: Wed Jul 31, 2013 5:46 pm
Posted: Wed Jul 31, 2013 8:19 pm
Rear disc conversion...
Easy-take the axles to Ed to properly remove backing plates.
Brackets will go on when you put axles back in. It really is a bolt-on affair.
Not much work needed at all.
Posted: Thu Aug 01, 2013 9:00 am
by Eagle_Adam
Laecaon wrote:woot!
indeed!!!!
my brothers truck needed new exhaust so the right answer is to cut mine off for his truck and get new exhaust for mine right???
Posted: Thu Aug 01, 2013 9:04 am
by Eagle_Adam
flatcat19 wrote:Rear disc conversion...
you make it sound so simple....
But its not
and i doubt ed will have time to work the bearings, ill drop em off to my machinist
