Rutt-roh! Look who's back.
Got the call from my Dad Sunday night that he thought his '64 smoked a piston/pistons again. He put the Paxton back on and thought he had lugged it a little too much. It developed a miss that progressively got worse and started smoking badly. By the time it was dropped off yesterday morning it was almost impossible to start, was running on 4 or 5 cylinders, and had almost no manifold vacuum. I was expecting to have to pull the engine and break it down. But first...
-Pulled the plugs. 3,7,6 & 8 extremely fuel fouled.
-Compression test. All 190-195 except for #8 -- 260psi! What?
-By this time I noticed a huge puddle of fuel under the car.
-Hooked up the fuel pressure gauge and cycle the key on and off. 45psi then immediately dropped to zero. Repeated 3 times. Bump starter over and fuel poured out #8 plug hole.
Yup, just a stuck injector. Replaced it, cranked the fuel out of the cylinders, cleaned and reinstalled the plugs. It fired right up, ran great and had 20in manifold vacuum. Took a while to cook all the fuel out of the exhaust system but all better now.
