Page 11 of 19
Re: The Blue gO_0n Build?
Posted: Mon Dec 23, 2013 5:54 pm
Nylocks suck. All about crush nuts.
No need to remove the wheel.
Posted: Mon Dec 23, 2013 9:49 pm
by H5WAGON
A boltless solution...
From a mustang site.
Might not clamp down far enough though.
Ebay...
http://www.ebay.com/bhp/leaf-spring-clips
Posted: Mon Dec 23, 2013 10:25 pm
by H5WAGON
This type installed....with flaps bent over.
Posted: Mon Dec 23, 2013 10:47 pm
I prefer the bolt method, as you stated, it probably has more tension. Tension stops the leafs from sliding between each other. Thus stopping axle wrap.
Posted: Tue Dec 24, 2013 2:33 am
by Doctoraudio
I forgot who.
But a guy was telling me about drilling thru the spring to do that.
And only using one bolt on each side of the spring.
I am interested in other thoughts.
How feasible is that?
Posted: Tue Dec 24, 2013 6:30 am
I don't think you'd want to do both sides of the spring, if you mean to the front and the rear of the axle. Kind of takes the spring out of the spring. The way it was explained to me was to was that you wrap/clamp the front to essentially make them solid(ish), like a trailing arm. Old hot rodder trick.
Posted: Tue Dec 24, 2013 11:39 am
Drilling leaf spring sucks. Also like driven said, you only want to do the front or rear, and each has its strengths. For our applications, keep the clamp in front of the axle.
Posted: Wed Dec 25, 2013 5:29 pm
by Draynor
All new Moog steering components were under the tree this year
Posted: Wed Dec 25, 2013 6:26 pm
by Doctoraudio
Is that motor done yet?
Posted: Wed Dec 25, 2013 6:27 pm
by Draynor
Pretty much
Posted: Wed Dec 25, 2013 6:29 pm
Ha nice dude. Jelly
Posted: Wed Dec 25, 2013 6:34 pm
OOOO nice!
You may want to order a few bushings while you are down there...
LCA/Swaybar/TC rod bushings. Luckily those are all cheap.
Posted: Wed Dec 25, 2013 6:36 pm
by Draynor
Yeah, gonna order the sway bar ones for this 1" bar I have. But I might be getting some adjustable LCA's and T/C rods...So might not order those bushings just yet.
Posted: Mon Dec 30, 2013 9:38 pm
by Draynor
Finally picked up the BMW seats from my friend
The color is close to the 510 stock red, but not perfect. I am thinking I might try and find the red vinyl paint for the BMW seats and paint the panels and such to match, since they are very faded anyway.
Also found 1 center cap at "H5WAGONS's" house, fits perfect! Anyone know what it's from? Looking for 3 more or a set!
Posted: Tue Dec 31, 2013 6:22 am
Looks like the caps I had on my '80 210.
Posted: Tue Dec 31, 2013 6:26 am
I was thinking 210. Gray would know.
Posted: Tue Dec 31, 2013 9:42 am
by Doctoraudio
80's 210
Posted: Thu Jan 02, 2014 2:12 am
by Eagle_Adam
Sneak peek
It's almost done
Posted: Thu Jan 02, 2014 4:43 pm
by Eagle_Adam
Ready and waiting for Laecaon to get off work and tune the carbs
Got some cleaning done too
Before
After
Posted: Thu Jan 02, 2014 11:21 pm
by Draynor
