my 77 kingcab
Farmer Joe
Re: my 77 kingcab
#201
Post by Farmer Joe »
okie dokie
drove to work.. did just fine.
just took my break to test if the belt was gonna squeal with the headlights on. it does... pretty bad. stupid old belt.
gotta see if i can tighten it up anymore when my shift is over. anyone got any grape jelly? lol
noticed i might have installed the passenger side rubber isolator upside down.. the oil pan seems to be sitting on the crossmember oh so slightly.
makes the whole truck buzz at around 35-40mph.. kind of annoying..
something in my steering column likes to make a ton of noise from the vibration too.
just in the 30 miles ive put on it, its smoothed out some more.
it runs really well.
im diggin it!
more to come...
KLH620 KA24DE FS5W71B HF37
Re: my 77 kingcab
#202
Post by 510freak »
Woot!
Minor adjustments they be that :thumbs:
Farmer Joe
Re: my 77 kingcab
#203
back again.
50 miles yesteday.. another today..
noticed at lunch thats its smoking. but only on acceleration. mainly right off ildle and it stinks like carbon and fuel..
i think its running kinda rich.. these small cams dont help either.. the ports did have alot of carbon in them, so running fuel across it is prolly burning off now..
in any case, its running better and better everytime i drive. it.
the engine rubbing on the crossmember is getting more and more annoying too. ill fix it next weekend..
Re: my 77 kingcab
#204
Better to catch it before it rubs a hole.
Farmer Joe
Re: my 77 kingcab
#205
yeah, its on the top of the list for when i have time.
i think im gonna pull the steering wheel off and see whats rattling in the column. its getting louder. lol
in other news, this engine smokes. typical DE issues.. never seen a DE not smoke when it was over 100k..
not a big deal. gonna get the cams and a tune up on it, and i bet itll stop loading up so bad.. its over carbed. i miss my long duration cam events... lol
jayden71
Title: Bewb Captain
Cars: '71 Viagra blue 521
'79 Patina KC 620
Re: my 77 kingcab
#206
Post by jayden71 »
Are you still running the L series 5 spd that I sold you years and years ago?
With the bent shifter?
Farmer Joe
Re: my 77 kingcab
#207
jayden71 » Thu Oct 30, 2014 12:57 pm wrote:Are you still running the L series 5 spd that I sold you years and years ago?
matter of fact, i am!
prolly shouldnt say anything, but this trans has been pretty good to me. it lasted behind 3 engines, and is on a 4th now.
i would like to have a C-type ka trans, but that cost $$..
Re: my 77 kingcab
#208
My steering wheel was wobbly in my B210. I had to pull the horn button and tighten the bolts. Glad that shit didn't pop off while driving.
Speaking of. I have a datsun wheel adapter and a choice of steering wheels to install in my 720. Think I might go pull the wheel off that black 620 and see what adapter it is. Maybe it's a grant! Maybe its a maybolene. Bahha.
Farmer Joe
Re: my 77 kingcab
#209
ive had this truck for 7 years today...
its come a long way...
Farmer Joe
Re: my 77 kingcab
#210
well the plates are expired now.. state said on the registration notice that i have to get new plates too.
kinda bummed. i dont wanna pay for new plates either..
hopefully tomorrow i can get a bit of work in on the truck.
gonna try and fix the motor mount issue that lets the engine set of the crossmember.
get the other steering wheel on it.
find whats vibrating in the steering column.
get a new throttle cable.
i need some tight 90* 2.5in tubing bends to finish my exhaust too. i dont want it blowing on the tire anymore. the oil smoke makes it not have much traction sometimes.
more to come..
Re: my 77 kingcab
#211
Why are they telling you new plates are required. Did you change counties or something?
Farmer Joe
Re: my 77 kingcab
#212
idaho has a 7 year plate rule. just another way to make revenue.
Farmer Joe
Re: my 77 kingcab
#213
alrighty..
got new tags, put a new throttle cable in, flipped the motor mount on the passenger side, and cranked up the driver side torsion bar. whooo...
also put oil in it..
Farmer Joe
Re: my 77 kingcab
#214
wooo...
drivin it to boise and back again.
it does pretty well on gas. but i have been driving the 2500 recently. that fucker is only getting like 11mpg...
noticing that the heat is never coming up. temp gage stays in the cold. the first time i drove it before the cold snap, i did get it past the cold section, but just a tiny bit.
the radiator is hot to the touch when its ran for a while. i get heat from the defrost too.
its the same temp sender from the last engine too, so i trust its working.
id have to guess the thermostat is stuck open. at least id think it would be. i never pulled the t-stat housing, so for all i know it might not have one at all.
more to come...
Has thanked: 119 times
Been thanked: 24 times
Re: my 77 kingcab
#215
Post by Ni10 »
if the fluid is moving soon as you start it up, I'd say the stat is open or their isn't one also. Might want to install one since winter is here, you'll need the motor to warm up quicker, other wise it will always be cold blooded.
Re: my 77 kingcab
#216
oregon has that rule too. It seems like they have only applied it "Sometimes". Seems like the older rigs with the yellow/blue they never say anything. The new white with green tree needs to be replaced cuz the reflective shit isn't as reflective. I don't think it has anything to do with cops being able to see, not see. It has to do with the red light cameras. When they flash it lights up your plate.... Notice it's not reflected straight behind or just to the sides. But if you hit it with light at some angle the shit lights up? haha. Red light camera fucks!
Has thanked: 2 times
Been thanked: 2 times
Re: my 77 kingcab
#217
Post by RedBanner »
Waahwahsington now has the 7 year rule now too.
MicroMachinery
Re: my 77 kingcab
#218
Post by MicroMachinery »
Fuck that.
Re: my 77 kingcab
#219
Never heard that about Wa or Or either. Every one of my cars has plates older than that. Original yellow plates on my Cutlass black '35 plates on my pickup. Even the Christmas tree plates on my Neon and El Camino are close to 20 years old.
Greedy bastards. It never fucking ends.
Re: my 77 kingcab
#220
Post by Ni10 »
DRIVEN » Wed Nov 12, 2014 6:39 am wrote: Greedy bastards. It never fucking ends.
AMERICA land of opportunity. out of control.
where's the Canadians when you need them.
said I'd bring the matches...... :D
