It looks good, I used a stock Ford Courier power brake booster/master on my 47 Chevy truck, I also used an automatic transmission, so I deleted the clutch pedal.
I used the stock frame with a AMC Pacer front clip on my truck, they said I could not lower it with that setup, but it was plenty low enough, but I would never do it again, because the Pacer bushings just are not made for a V8 and the weight of the truck, it worked great for a while, but when I backed up everything just got out of shape even though everything was new, to much weight, but it drove like a car, smooth.
If you keep picking away at it, you will finish, bet that will be a day for a "finished the truck" party.
