soon to be LZ2.3 521 :)
Re: 521 owner here
While the wheels are off the ground....
Grab the wheel-not steering wheel-and give it a brisk shake left and right. Feel any clunks/looseness?
Now, top to bottom.
Top to bottom movement, you may need to put the jack under the LCA to load the suspension.
You may also need someone to hold the steering wheel while you doing your shaking.
If there are any loose parts an alignment is just a waste of money.
Now, top to bottom.
Re: 521 owner here
With steering components-loose is broken.uberkevin wrote:flatcat19 wrote:Those look familiar.
I have a feeling something is loose or broke down under there.
Broken I don't think so, could be loose forsure.
Please play again.
Re: 521 owner here
Didn't know we were playing.
Loose in what way? Loose where.
Edit* I didn't see the post some how...
- Has thanked: 430 times
- Been thanked: 1295 times
Re: 521 owner here
As he said, after a certain point loose is broken, if it moves enough to change your alignment, it is broke.
When stuff moves around, it will change the characteristics of your ride, like stepping on the brakes and having it do something that is unwanted/undesired, and lifting it off the ground doesn't help when looking for issues, as the parts move to a position that is not normal, and everything gets tight.
The alignment shop should be able to tell you everything that needs changed, then change it, take it back and they should align it, if they don't work that way, go somewhere else, that is what Les Schwab does for me, and I think it should be that way everywhere.
Re: 521 owner here
Bring it to me. I'll give it a quick finger.
I'll even look at your truck too.
Not even 10 minutes worth of time.
- Ni10
- Has thanked: 119 times
- Been thanked: 24 times
Re: 521 owner here
take a look at the tension rod bushings also. If they are old and cracked will compress when you put on your brakes, will change the angle of the lower control arm ( force the arm backwards ) and make it pull to the left or right.
- jayden71
- Title: Bewb Captain
- Cars: '71 Viagra blue 521
Re: 521 owner here
FAPFAPFAPFAPFAPFAPFAPFAPFAPFAPFAPFAPFPAPFAP...................EERRRRRRMERHGERRRD!!!!uberkevin wrote:
AHHHHHHHHHHHHHHHH.........
Thanks
- Eagle_Adam
Re: 521 owner here
soooo clean!!!!!!!
for now
for now
Re: 521 owner here
The white is super nice in there! If only it would stay clean, we'll see.
Wish it was coated py jrock so it would look a bit better but I think I did a good job painting it.
Re: 521 owner here
damn bro the valve cover looks good!
Eagle_Adam wrote:he who drives it like he stole it, is he who fixes it like he broke it
Re: 521 owner here
Thanks man, maybe could have done a couple more coats.
Ive been think about painting my 521 dash white. I think if I redo the suede on the dash same color just put some treatment on it so the sun doesn't fad it again and then paint the front part of the dash white it would make the suede really pop! And it doesn't cost much to do so I man do it.
Re: 521 owner here
i might even have you help me redo the dash pad in my 720, that is when i get the motor swap done
Re: 521 owner here
"I think if I redo the suede on the dash same color just put some treatment on it"
Re: 521 owner here
Hey it was yellow!!! I can paint the Datsun part yellow tho that would look nice.
