Page 12 of 37
Posted: Wed Oct 23, 2013 7:59 am
by Eagle_Adam
once the B is running i can focus on the KA swap
Posted: Wed Oct 23, 2013 10:38 am
by Skeletonbonez
gonna be badass dude. as if your truck wasn't fast enough already
Posted: Wed Oct 23, 2013 11:48 am
clean L20 with 5 speed behind it..... man that would be nice in the 720
Posted: Wed Oct 23, 2013 12:15 pm
by Eagle_Adam
Skeletonbonez wrote:gonna be badass dude. as if your truck wasn't fast enough already
never fast enough........... its an issue i have, just cant leave well enough alone.
by Eagle_Adam
izzo wrote:clean L20 with 5 speed behind it..... man that would be nice in the 720
yes, yes it would......
Posted: Wed Oct 23, 2013 7:33 pm
Eagle_Adam wrote:Skeletonbonez wrote:gonna be badass dude. as if your truck wasn't fast enough already
Nothing wrong with that.
To touch on what Draker said about the leak down testing...
Piston is at TDC. Air goes in. Blah, blah, blah.
If air would be leaking it will go up, down, or out.
Down-you need rings. Up-valve seats or seals. Out-HG.
I doubt you will need a rebuild though. KAs are damn tough.
You do not even need a leak down tester. The air hose from your compression tester will be fine.
You don't need the gauges-just the knowledge that you do or don't have to do A, B, or C.
On the minimum I would put new chains, tensioners, and guides on there. KAs love to eat chain guides.
Posted: Thu Oct 24, 2013 5:49 am
Definitely what Keith said. ^^^^
is how I am every time I hear that rattle
Posted: Thu Oct 24, 2013 7:24 am
by Eagle_Adam
already have a timing kit
but ive read quite a few times that Nissan guides are the way to go if you going to run em.
Ive also seen there some say to remove a certain guide as its "not needed" and "just ends up in the oil pan" which is an interesting concepts but also scares me to death
Posted: Thu Oct 24, 2013 10:41 am
by draker
flatcat19 wrote:Eagle_Adam wrote:Skeletonbonez wrote:gonna be badass dude. as if your truck wasn't fast enough already
You're right gauges aren't a requirement. Good tip on the compression tester hose. Gauges come in handy when you want to tell how big the leak is.. or the health of the cylinder in relation to the others.
Posted: Fri Oct 25, 2013 9:31 am
Eagle_Adam wrote:already have a timing kit
I've heard the same thing although I don't remember where. I haven't had the balls to try it yet.
Posted: Fri Oct 25, 2013 5:17 pm
I like leak down testing for diagnosis much more than a compression test.
The only thing I use compression testing for is oil consumption tests.
Other than that, I feel it's an outdated method.
Posted: Fri Oct 25, 2013 10:37 pm
by Eagle_Adam
There's always something about every car I've ever had that pisses me off.....
ALWAYS!!!!
In the 620, it's the glove box made from fucking cardboard....
So I set out to fix that!
Introducing a new metal glovebox insert for all 620's!!!
Once I have the first one in and working they will be FS
This will also provide a sweet place to mount the custom control box being made for my engine swap
Posted: Fri Oct 25, 2013 10:59 pm
Could also make a custom panel to go in there... so they could mount a head unit in there
Posted: Fri Oct 25, 2013 11:25 pm
by Eagle_Adam
The possibilities are endless now that Its not cardboard
Posted: Fri Oct 25, 2013 11:31 pm
I too like rust in my glove box
Posted: Sat Oct 26, 2013 12:11 am
by Eagle_Adam
Wont rust if its aluminum :p
Also wont rust if the PO replaced every seal in the truck for you
Posted: Sat Oct 26, 2013 8:25 am
by MicroMachinery
Posted: Sat Oct 26, 2013 9:44 am
by Converted_to_datsun
someone is already trying to sell those with that exact picture on fb ratsun
Posted: Sat Oct 26, 2013 10:11 am
by Eagle_Adam
Converted_to_datsun wrote:someone is already trying to sell those with that exact picture on fb ratsun
Yup, on FB his name is rods mods
Posted: Sat Oct 26, 2013 10:18 am
Price is a bit steep lol get yours and I'll measure it and make my own at work cheaper
