Page 13 of 46
Posted: Sun May 11, 2014 7:55 pm
by draker
Crossmember rear and rear exhaust hanger. Ebay seller sent me some dual points for freez.
Posted: Sun May 11, 2014 8:02 pm
by draker
Just ran out to take this:
Posted: Sun May 11, 2014 8:03 pm
by draker
gonna swap out the stock bolts for some a little bit longer. These are about 4mm too short.
Posted: Sun May 11, 2014 8:06 pm
Posted: Mon May 12, 2014 11:33 am
finally an update. plus.... you can throw it on the ground now!
Posted: Mon May 12, 2014 12:20 pm
by draker
izzo wrote:finally an update. plus.... you can throw it on the ground now!
Yes, just about. Still a few misc things I gotta take care of. I think I spotted the clutch slave leaking.. gotta tighten it up a bit more.. then bleed the brakes.
Then I'll get it on the ground and get the lights and shit working.. toss a temporary seat and take it for it's maiden voyage. Can't wait!!
Posted: Mon May 12, 2014 9:44 pm
by draker
Bled the brakes again today.. this time with a vacuum bleeder. Still soft as fuck... hmm..
Probably still air in there. Gonna need a lot more bleeding. Power bleeders, fucking want one bad.
Posted: Mon May 12, 2014 9:52 pm
Do what I do....
First make sure the MC is bled. Get yourself some 3/16 clear vinyl hose, or whatever size fits over the bleeder. Make a U on one side of a short piece of hose, maybe use a pop can tab?, and place over edge of reservoir, and the other side to the bleeder. Pump away at the pedal. I did this in car for my bench bleeding, and it worked great. keep pumping until you see no bubbles. Switch to the other reservoir, but now you have to keep an eye on the first so it doesnt go empty. Finally just connect a few feet of hose to a rear bleeder, open it up, and pump away (keep reservoir full)keep checking the clear line for bubbles (I like to make a few loops with the hose to trap bubbles, but I dont think its necessary). Then switch sides. There is no need for holding of the brake peddle, just tighten the bleeder before removing the hose. As long as the hose has no bubbles your are fine.
Finally, um, if this is the original MC, and you maxed out the throw on the brake pedal, You may have moved some sediment, and now its not happy. That is what happened to my MC. Went to bleed it, and bam it started leaking.
Posted: Tue May 13, 2014 7:42 am
by draker
Thanks for the info. I've bled everything a few times, but good point maybe a bit more air in the MC. I'll bleed that again. This is a new MC.
Stupid tiny reservoirs, gotta keep filling and filling and filling.. lol
Posted: Tue May 13, 2014 8:59 am
by Ni10
when bleeding the masters, take the bleeder hose and return it to the reservoir for continuous refills.
Posted: Tue May 13, 2014 9:31 am
by draker
Ni10 wrote:when bleeding the masters, take the bleeder hose and return it to the reservoir for continuous refills.
For sure, I'm talking at the wheelz yo!
Posted: Tue May 13, 2014 12:14 pm
by Ni10
draker wrote:Ni10 wrote:when bleeding the masters, take the bleeder hose and return it to the reservoir for continuous refills.
longer hose then.
just kid'N
I take it your bleeding by yourself. If so, is the catch bottle below or above the wheel cylinder ?
if it's below, think maybe when you stop to refill the res that bubbles are floating back up into the wheel cylinder.
I always put the bottle above the wheel cylinder (sitting on rag) so when I refill the res, the bubbles float to the top. When you proceed with bleeding, the bubbles come out the first time up push down the pedal.
anyways, just thinking, maybe.
Posted: Tue May 13, 2014 12:18 pm
by draker
Below, but vacuum bleeder. pulling fluid down but still valid point. Yes, one man bleeding operation.. with very little space to work. lol
I'm gonna bleed to shit out the master again. It's suspect.
Posted: Tue May 13, 2014 12:25 pm
by Ni10
well that changes everything - sorta.
you didn't purchase the masters at Vatozone, did ya. ( whispering - please say NO )
Posted: Tue May 13, 2014 12:38 pm
by draker
Ni10 wrote:well that changes everything - sorta.
Got it from rockauto.. it brand new. Not reman..
I bought a reman first and it was total shit. Returned and bought a brand new one.
Posted: Tue May 13, 2014 6:00 pm
by draker
Bled the master again, boom. Pressure!!
Posted: Tue May 13, 2014 7:13 pm
YAY!
Posted: Tue May 13, 2014 9:27 pm
by draker
Posted: Tue May 13, 2014 9:34 pm
Lol, i took your brand new one
Posted: Tue May 13, 2014 9:37 pm
by draker
izzo wrote:Lol, i took your brand new one
Yeah, but I still would have needed one more. lol Fuck.
