Crystal. My first pos.
- Spoona_Jay21
- Cars: 1978 620 KC
Re: Crystal. My first pos.
thanks guys. means a lot!
i tried to start the car today. no dice... maytbe it was cold...
I'll have to see what happens when i have time.
- Has thanked: 430 times
- Been thanked: 1295 times
datmo wrote:thanks guys. means a lot!
Do you have the chokes working?
You beat me to it flatcat
My car must be an anomaly... Just keep pressing the gas pedal while cranking. My car would start in January first revolution by timing the gas pedal to where in the revolution the crank was. Then it was just a matter of keeping it running for about 30 seconds.
No, I don't need a choke.
I ran my single weber with no choke and the dual carbs start just fine with no choke as well.
The car wasn't starting because the carbs had too much gas and not enough air.
I was trying to fix a part of the linkage so the gas was always being pressed.
I took a few pics today.
I'm wondering if anyone knows why my 510 lags?
I press gas and the car doesnt really move until a real good 5 seconds or so.
And my pedal gets stuck but I added a return spring to deal with that issue.
I am idling too low so I'm gonna go to a guy named Bob Higgins down in Socal and see what he can do for me.
Since I plan to daily my 510 after realizing that i love this car so damn much, I want it to be exact.
the back sits higher a bit and i loveee the look.
Su's aren't tuned right.. let it warm up for 5-10 minutes before you tear ass. thats what happens when you have no choke. PS, weber isn't SU, SU isn't weber. just cause you ran a weber with no carb doesn't mean squat about SU's.
Tho, if tuned right you don't need a choke I've always seen people use chokes on SU's. even if just a little bit.
Tune those carbs out right man. I posted a link to a uni-syn
These are not your Weber.datmo wrote:No, I don't need a choke.
Allowing more air in is what the choke is for.
Please play again.
izzo wrote:Su's aren't tuned right.. let it warm up for 5-10 minutes before you tear ass. thats what happens when you have no choke. PS, weber isn't SU, SU isn't weber. just cause you ran a weber with no carb doesn't mean squat about SU's.
I did let them warm up for the times that it did start.
I'm going to get the tool and see what I can do but I'm also going to the shop for the other problems so I'd rather him do it professionally.
I really don't think I need a choke.
The car could have not started for multiple reasons.
I hadn't started the car for awhile before that so that's a variable but I'm not one to be exact.
I realize that now. I'll play again. Sure why not. lolflatcat19 wrote:These are not your Weber.datmo wrote:No, I don't need a choke.
Please play again.
Why are you taking it to a shop?
How are you ever going to learn to do work?
For the money you spend at a shop you can buy your own tools and have the satisfaction of doing it yourself.
Well the guy knows a friend and he said he showed him a bunch of 510 stuff because he had a few.flatcat19 wrote:Why are you taking it to a shop?
I was gonna ask him to teach me to properly do it and I also have the other problem I have not looked into yet.
When i press gas, 4-5 second lag..
If I'm doing it myself, I'd rather have a tool to help.flatcat19 wrote:Also...not many people have a UniSync tool. It's kind of an old-school thing.
I'm a noob so I'd rather get it right and not fuck up.
I dont use a choke. I can full throttle my car cold. I always had to choke my weber.
Tools to sync the carbs are a must. You will never get it right without it.
They seem like a necessity to me.Laecaon wrote:I dont use a choke. I can full throttle my car cold. I always had to choke my weber.
my license test is tueseday so i hope to get the car running and done by that night.
I gotta bleed my brakes and get some antifreeze instead of water
I actually talked to skib over text.
he's selling his s12.
