The never ending Project(s)
Updates coming soon. Been busy working. Had a lot happen over the last week. Pics and info coming tonight after work. Here's a pic of a dildo I found in the back of a customers car.
Because there's only one dildo.
Appears double ended tho
So got the blue b210 running. It backfires thru the carb. i sprayed some starting fluid around the base of the carb, and the idle went up. replaced the two base gaskets, tightened some stuff up, swapped throttle shaft portion of carb as its separate. Ran better, same shits.. backfiring thru carb etc. I did play with timing also, helped some, but still same effect. Shitty, ordered a carb adapter for the weber, and a linkage kit.
Last thursday I mash down to tillamook and back, got an exhaust for the blue car. Score!!! Friday morning I get up, run to the gas station and get some gas for the blue B. get it running (see above issues). Friday evening rolls around, and I need to go get my kids. Started my car and it was running on 3 cylinders.... SHIT!!! Do all the usual checks, vacuum, spark etc.... everything was fine. I pulled the valve cover and for some reason #7 pushrod was super loose, but the adjuster was tight... Guess what that means? Dropped valve seat (At least in this case, it was... Could mean something else too).
Anyways. Had a spare head laying around. Did a leak down test, no leaks. Text the previous owner and he said one of the tappet tower bolt holes were stripped... Helicoiled and installed. Turns out two of them were stripped
Got the new head on, timed and tuned it the following night. cut the choke cable back some... Dude who installed it didn't trim it down at all and it wasn't fully working and would bind up.
Anyways, everything is tight, tuned, running right. Even sprayed some cable lube into the choke cable. Shits like butter! Love this little car lol
Pics, in an order of which I don't know
Got the 74 running! has a stumble/hesitation off idle when giving it throttle. deal with that later.. For now, it's good. Timed/tuned best I could. temp stays there. need to work on a little bit of wiring. At this point I just need to throw money at it.
I am buying a 521 here soon. I need a truck to haul things. After I get the 521, I will be throwing a wad of cash at the blue b210. Complete brakes front and rear, slave cylinder, ign switch, light switch, install seats, this that....
Or perhaps a multicolored one that runs and drives a lot like an '85 720?
was thinking the same thing
- Justinberni
- Cars: 1986 720
If youre buying Waynes 521 on my old 720 frame let me know when youre picking it up, ill stop by Waynes when youre there.
also, that dildoe in that truck reminded me, last week looking for a wheel lock key i found 3 pipes, some weed, a dildoe, and a porn collection all in one car, that guy partied...
Lol fuck that nice blue one, that dude is a joke. 2300 then 4 days later its up for highest bid, last i saw 4500 bucks.... stupid.
There is areally really clean one down the street from me up for 4 grand. I went and looked at it, had minor paint issues, stock carb was garbage, brakes needed adjusted and steering needed work badly. He says its fine, but lol no...
And it would be a multi colored one that used to be a 720 lol....
- Justinberni
- Cars: 1986 720
lol!
- Eagle_Adam
Need more pics of this "74" u speak of....
:p
:p
Aye sorry man. Haven't had money to do anything, so it's just sat
Life has kicked me in the dick recently.
Replaced the sway bar end links on the butterscotch one. mucho better! need to do the frame bushings, too. Another time. Have all new bearings for both cars on the front & races. just need to order up the wheel seals. Been doing this and that lately. cleaned up my daily, been starting to work on the blue car again. lack of money slowing me down.
Finally got my taxes sent off, so waiting for that to get back. hopefully its all good this time. was mail audited, so filed and amended return. hopefully that fixes it then I can get my money back and get shit taken care of. Want to buy that 521 off wayno, get this blue car going, this and that. My car needs moar lowered and shits and stuffs and things, window tint, steering box, idler etc....
I think you may have missed out on that one.izzo » Fri Mar 18, 2016 8:49 pm wrote:Want to buy that 521 off wayno...
izzo » Fri Mar 18, 2016 8:49 pm wrote:Replaced the sway bar end links on the butterscotch one. mucho better! need to do the frame bushings, too. Another time. Have all new bearings for both cars on the front & races. just need to order up the wheel seals. Been doing this and that lately. cleaned up my daily, been starting to work on the blue car again. lack of money slowing me down.
That truck is gone now Tim, a guy offered me $1500.00 and I took it.
Ok
Exhaust removed, 14 resonator installed. braaaap.
Got a tip about some 13x6.5 turbines. So, road trip! Working on cleaning them up, slowly but surely.
Zach was in the neighborhood, so he stopped and we chatted a bit. was good seeing him.
Met a z guy thats local to me. We are gonna try and get a nissan meet up going up here. I also met someone who wanted to buy a datsun, he finally got one. A white 620. once he gets back from leave, we will be getting together. No pics of the 620. I also found someone local that bought a 4 door white b210. once I get more info and pics of that, I will share.
New front brakes on the blue car, new bearings... Rear got torn down and cleaned, re lubed, adjusted, new cylinders. need to bleed the rear, then I just need to finish the throttle cable and get a clutch slave rod and she will move on her own.
