Meet Buttercups aka Reeses
Re: Meet Buttercups aka Reeses
Sweet glad you were able to get the doglegs Kenny.
Has the latch gone past the springy part?
Try holding the handle up and rotating the latch back,sounds like the latch is in lock position
check the latches on the door. the part that rotates needs to have a rubber boot on it. my passenger door lost it and it wouldnt double latch.
Also might need to remove the door panel and make sure all the rods are returning properly.
I actually had this issue one night, it was super cold. Drivers door would not latch at all. After about 5 minutes of constant slamming, it stuck. Has been fine since...
- peanutbuttercups
- Cars: Rising Sun Orange g00n
2005 ACURA RSX type s
1974 Datsun 620 (the maybe someday build)
1986 Mazda b2000 - Location: The real NOR-CAL
- Has thanked: 1 time
Lou,
Thanks buddy, I was stressing out all week that It get crushed before I could get them. Best 25.00 I ever spent I think
Leacon,
Thanks man!! Slammed the door a couple of times (which I hate doing) working fine now.
Leacon,
Blah Blah Blah.
Yea I hate slamming too. I actually want to go through and re lube the door latch.
After I rebuilt the door hinges all my friends were accidentally slamming my doors
- peanutbuttercups
Back from the shop!
Before
And Then
Then rest I'll do myself, I have to fill the holes where the trim pieces were, finish sanding the rest of the rust, and get this baby into paint.
I have been thinking of just doing an Orange primer sealer (for now). I saw it on a orange pickup at a show once and I liked it.
Oh, I did have one more thing done to it.
Lowering blocks
Needs Moar low in the front.
Before
And Then
Lowering blocks
Blah Blah Blah.
Looks great Kenny, Sweet repair you got on the doglegs
- peanutbuttercups
Thanks Mang!!510freak wrote:![]()
She's not afraid to take a corner now that she's lower in the rear. The geometry was way off.
Previous owner installed a rear sway bar from an MG, and the muffler is rubbing on that a little, but easy fix.
Blah Blah Blah.
Get it dialed,and you will be in the corners like no tomorrow
Get her down to bare metal and epoxy primer... Won't draw moisture and seal that baby up. No rust!
orange primer isn't to bad. Check out my old whip.. It was dubbed Creamsicle. White chased with orange.
loved that 620 izzo
anyway on topic goon looks nice man im gonna have to tackle body work at some point little nervious about it
- peanutbuttercups
Update! I'm Lagging big-time, busy Time of year! Sorry
Izzo, I remember that truck
If you Didn't know I have lurked over there (Ratsun) since the beginning. I Have been trying to get into the Datsun game for a while. I guess I should do a thread over there too.
Bonvo, Thanks
So update. I shoot the shit with all the car guys around here, and I kept hearing good words about this one shop. I dropped by a while ago for an estimate, the owner said if I was patient, it was there slow time of year, they would work on it in their downtime. He quoted me a price that I could not refuse.
They are going to do a two-stage paint with clear, Doorjams, and repair the rear quarter with metal, so no fiberglass at all
I dropped Buttercups off on Monday so hopefully she will be back soon.
FYI if I don't hire out some of this it's never going to get done, too busy right now and getting busier with holidays coming. I want this g00n done so I can play!
Bonvo, Thanks
Blah Blah Blah.
Sweet deal Kenny..
Base/Clear is going to be purdy
- peanutbuttercups
Last edited by peanutbuttercups on Sat Sep 03, 2016 10:28 pm, edited 1 time in total.
Blah Blah Blah.
- Ni10
- Has thanked: 119 times
- Been thanked: 24 times
went through your thread and didn't read anything about the rear lowering blocks. Did you have a set of blocks / U bolts from a previous project or ?????
- peanutbuttercups
No I had the welding shop make me a set. He has made sets for all kinds of cars. I hate I hate working under cars! He had a lift their, and he was reasonable. Hopefully she will be back from the paint shop soon.Ni10 wrote:went through your thread and didn't read anything about the rear lowering blocks. Did you have a set of blocks / U bolts from a previous project or ?????
Blah Blah Blah.
- Ni10
sorry but got a few more questions.
Can you get measurements of the blocks when the wagon get back home.
also, did the floor get cut so the drive line didn't hit the hump?
- peanutbuttercups
Sure they have 5 degrees of angle.not sure about exact measure, can measure when it gets back. I have not cut the trans tunnel yet, I am being very careful until I can get to that.Ni10 wrote:sorry but got a few more questions.
Blah Blah Blah.
- Ni10
thanks, would definitely appreciate that.
did you put bump stops on the front?
- peanutbuttercups
Ni10 wrote:thanks, would definitely appreciate that.
Welcome, no bumpstops, I'm going to run mr2 or rabbit inserts soon. Not sure yet.
Blah Blah Blah.
- Ni10
I'm about ready to start on my 68 wagon (next year )and trying to get idea's on which direction the wagon will go.
I've read if bump stops are not to be used that the car will over steer. just saying.
