Okay, so I am losing coolant. I drove again when there was a sun break, and noticed the smoke was white. Let it cool down and checked the coolant, it was low. I pulled all the plugs while it was hot and no smoke (engine bay). No visible leaks in the engine bay or the heater core, no drips, no smoke. Only evidence is the reservoir level rose and the radiator level was low. I'm not sure if the radiator level drop is equal to the amount of rise in the expansion tank, but that would point to a faulty radiator cap, right? Seems kinda obvious now that I wrote it out, but I take nothing for face value anymore. Been chasing my tail with this motor too long to start assuming anything.
Good news is the motor seems healthy other than the smoke, full power, smooth idle, no stumbling, no codes. Noisy third gear, slight whine.
I pulled up some of the weather strip from the trunk, peeled the adhesive, then reset it using the truck lid itself to hold it in place instead of binder clips. I haven't seen any water in the trunk yet so I'm hoping I won't have to keep the car covered anymore. But it hasn't really been raining enough to know, I might dump a bucket of water over the rear to see how it does.
Polished one wheel up some, it looks good, but I wish I would have started with a more course cut, the medium wasn't quite enough. I think I'll get some more compound before I do the rest.
I'm gonna try and make it out to Canby tomorrow sometime, I've got 510 stuff to let go of and a few things I might look for. Look forward to meeting any of you that are there.
