Page 25 of 28
Re: the mine now coupe.
Posted: Wed Jul 30, 2014 6:55 pm
by RedBanner
Yes. Had to modify them some. Wich is not great, but ill get another set and see if they work without serius "adjustments.
Posted: Fri Aug 01, 2014 3:18 pm
by RedBanner
Did way better on fuel on the.way to the beach, was into the throttle the whole way and used 3/8 of a tank.
Posted: Fri Aug 01, 2014 6:09 pm
by RedBanner
Alright, lol, so this is weird, all coincidence, im not smart enough to think this far into the future.
I swapped gears, swappped tranies, im running a taller than stock tire. My speedo is dead on.
Posted: Fri Aug 01, 2014 7:14 pm
by draker
RedBanner » Fri Aug 01, 2014 7:09 pm wrote:Alright, lol, so this is weird, all coincidence, im not smart enough to think this far into the future.
Woah.
Posted: Fri Aug 01, 2014 7:32 pm
Witch doctor.
Posted: Fri Aug 01, 2014 7:41 pm
Datsun Gods approved of your work.
You were rewarded with perfect speed.
Don't abuse it.
Posted: Fri Aug 01, 2014 8:09 pm
by RedBanner
"Do you know how fast you where going" the officer ask while he inserted a fresh tazer battery
"..... yes, I do" he admitted honestly,
Posted: Fri Aug 01, 2014 8:34 pm
lol did you get pulled over?
Posted: Fri Aug 01, 2014 8:46 pm
by RedBanner
Nope.
Posted: Mon Aug 04, 2014 8:12 am
by RedBanner
So, I filled up thursday morning, got home last night with almost 3/8 of a tank, I was fully prepared to get much worse gas mileage switching from that old webber and a 1200 to a 1.4 with su carbs... but I actualy think im getting better mileage. Did not expect that.
Posted: Mon Aug 04, 2014 9:35 am
That's pretty damn good mileage.
Posted: Mon Aug 04, 2014 9:51 am
by RedBanner
Ill fill it up and get some numbers when shes dry, but in contrast, I usually fillup before I leave the peninsula, or at the latest westport. Yesterday I planned on stopping at westport, but was just over half a tank, decided to keep goin.
Posted: Mon Aug 04, 2014 9:57 am
Ever have a shake from the mini mart there? Omnomnom.
Posted: Mon Aug 04, 2014 5:12 pm
RedBanner » Mon Aug 04, 2014 8:12 am wrote: I was fully prepared to get much worse gas mileage switching from that old webber and a 1200 to a 1.4 with su carbs... but I actualy think im getting better mileage. Did not expect that.
Not too surprising. Webers aren't famous for their fuel economy. IMO they only make a decent upgrade compared to a worn out or otherwise fucked up Hitachi. SUs are just great carbs.
Posted: Tue Aug 05, 2014 1:03 am
by RedBanner
True, It was doing pretty good for a weber, if I.cleaned and tuned itbbefore a long trip. Untill it shit its guts out at least.
Posted: Tue Aug 05, 2014 3:21 am
Completely agree Jess. Webers are just alright, good aftermarket support, and people tend to like them, but yea... SUs are probably the closest thing to EFI that not EFI.
Posted: Tue Aug 05, 2014 12:59 pm
by RedBanner
"I got home with 3/8 of a tank"
Getting suspicious
After I drove to the airport, then to home depot, lunch, and then home.......
Filling my 2 gallon gas can before I go to work tomarow, just incase.
Posted: Tue Aug 05, 2014 1:29 pm
Datsun gods will give you one working gauge, gasoline or speedometer; you can't have both.
Posted: Tue Aug 05, 2014 1:39 pm
Last night I got home from work on Empty, like left turns dived the needle under the line, and right turns brought it back above. Today, the car had a good needle width between empty and the needle.
But yes, be suspicious.
Posted: Tue Aug 05, 2014 1:40 pm
by RedBanner
Bwaaaahahahahaha
Its always worked perfect, but I did upgrade to a 50amp ir alt (+20ish amps lololol)
Maybe its causin some weirdness. Maybe ill just fill it up and see what it will hold at this point. Anything more than 5 gallons would be suspect as hell.
