Page 27 of 50
Re: Jacob's goon build
Posted: Fri Apr 17, 2015 4:34 pm
Ok, homework done wrong.
Driveshafts.
I knew this the whole time, but I have also heard differently in person over the years.
Sedan driveshaft in a wagon works with the 71B known as the Long tail trannys, but it is a tad short.
It does not work directly with a 71C Car tranny, (KA,SR,VG, CA).
All bolted up, and jammed all the way into the CA's transmission, the motor wants to be about 1 inch forward of the crossmember.
That will not do. So I need to take some out...
But even at current, there is almost enough room for the clutch fan! An inch back would provide plenty!
Posted: Sat Apr 18, 2015 1:20 pm
All better!
So I did some research, decided to just cut the driveshaft myself. Aligned it, threw it back in the car, spun it checking for runout, got it nearly perfect, welded it. Ill balance it once I get it on the road.
To show what my problem was, motor mount a bit off (other side was worse).
Then current back of motor to firewall clearance:
Fan to Radiator clearance, or lack thereof:
And the motor where it should be!
Posted: Sat Apr 18, 2015 10:17 pm
Started on the transmission mount. Should finish up tomorrow. Also cut a giant hole for the shifter. I wanted to shove the transmission high. Pictures, I forgot, tomorrow.
Posted: Sun Apr 19, 2015 9:55 am
All caught up on your build. Too good.
Posted: Sun Apr 26, 2015 9:07 pm
Posted: Sun Apr 26, 2015 9:35 pm
I also picked up a S13 SR20DET MAF. Definitely need to chip the CA's ecu now.
Posted: Mon Apr 27, 2015 5:21 am
Those valve keeper tools are flippin sweet.
Posted: Tue Apr 28, 2015 12:01 am
by yello620
Microsquirt.
Posted: Tue Apr 28, 2015 11:38 pm
Hurt hand, not feeling like too much wrenching. So instead planning out other things. Just ordered a EPROM programmer, 28 Pin ZIF (Zero Insertion Force) socket, and a solder sucker (some how I have never had one of these).
Need to order a few chips, and then I try dabbling with that stuff. First up will be editing the voltage range for the MAF so it will work right with the SR MAF.
Posted: Tue Apr 28, 2015 11:41 pm
Im just not quite feeling like doing a stand alone right now. Down the road I am actually thinking of going with Nistune (which is based in Australia, land of the CA18DET it would seem like). Although deleting the MAF entirely would be nice.
Posted: Sat May 09, 2015 6:29 pm
Posted: Sun May 10, 2015 12:00 am
ECU Time!
ECU showing all!
Bottom of ECU, desoldered chip
Top of board, chip gone.
Supplies! Always nice to see a company give out stickers and other things
On the left is a new chip, in this case its a 512k eeprom, stock is a 128k eprom. Ill get more into this later.
And here is the chip inserted into the ZIF socket. ZIF=Zero Insertion Force. A little arm tightens the chip into the socket, as well as releases it.
ZIF socket soldered in.
From the top side
And what it looks like all together.
Posted: Sun May 10, 2015 12:21 am
:Jedi mind trick:
You want to come wire my truck with the coolest of tech goodies.
Posted: Mon May 11, 2015 7:28 am
by draker
Are there tunes out there you can burn into that? Or do you have buy them and burn em?
Posted: Mon May 11, 2015 5:07 pm
Plenty out there, and its all pretty easy to modify yourself with some software.
I havent gone down that road yet, but Ill report back with the findings.
FYI I dont like paying people to do something I can.
Posted: Mon May 11, 2015 9:50 pm
by draker
I hear that! I wasn't sure what was floating around. This is all common with the Z32 also.. but mine is all stock and I haven't went down that road either.
Posted: Sat May 30, 2015 4:00 pm
Geez, Clutches are spendy.
Bought a Centerforce dual friction.
Posted: Mon Jun 01, 2015 6:06 am
But I believe the old adage "you get what you pay for" can be inserted here.
Posted: Mon Jun 01, 2015 9:52 pm
Posted: Mon Jun 01, 2015 10:31 pm
Those are very pretty.
