BLUE's Copper ZXT
- Has thanked: 669 times
- Been thanked: 243 times
Re: BLUE's Copper ZXT
047 by 71240z, on Flickr
popped off the timing cover , and the purple wedge did its job.
048 by 71240z, on Flickr
049 by 71240z, on Flickr
056 by 71240z, on Flickr
Grabbed a spare timing cover to use as a pattern holder for the bolts/spacers.
057 by 71240z, on Flickr
Quite a few of the parts on my 6ft x 4ft steel work (welding) table.
058 by 71240z, on Flickr
wrapped up the oil pump as well to keep debris out.
060 by 71240z, on Flickr
061 by 71240z, on Flickr
Gotta finish cleaning the surface on the head. (resting on a rubber mat .. so not to mark up the sealing surface )
059 by 71240z, on Flickr
^^^ So at this point after the pictures to do list
---------------TASK LIST-----------------------------
*Finish cleaning head-gasket sealing surfaces.
*Clean timing cover
*Clean out oil pan
*Clean out pickup
*Check/cleanout block breather
*Finish rebuilding the turbo.
*Put it all back together.
*Clean timing cover
*Clean out oil pan
*Clean out pickup
taking out block breather for cleaning/inspection
008 by 71240z, on Flickr
block breather mesh
015 by 71240z, on Flickr
pulling off pickup tube for cleaning.
017 by 71240z, on Flickr
block breather mesh
Cleaned out/up the oil pan , timing cover , etc etc etc ....
Laid them out on the black metal work bench.
Will do a final pass with a razor blad , scraper , and brake clean + gas cleaning where applicable.
018 by 71240z, on Flickr
Oil pan isn't as clean as I wanted to get it tonight , so I'll have to finish that tomorrow or soon !
019 by 71240z, on Flickr
Also picked up some green plasti-gauge from NAPA !!! When (2) other parts stores were less efficient and less willing ... NAPA was more than willing to make it happen .... Thanks a bunch to Michael for the help through the years !!!
020 by 71240z, on Flickr
Will be checking rod and main bearing clearances here soon.
The engine didn't knock (that I could tell) , so I believe all will be ok... just a smart move as always as you guys know.
Thanks for reading
Thanks for reading
Well wen't to do my plasti-gauge tonight .. just before pulling off any main/rod caps ... decided to grab the crankshaft and pushed in/out-wards to check quickly for any serious play ... there's play in the thrust-bearing :-/ ... how much ? ... I won't know until I find the dial indicator w/magnetic base .. pffff [:rolleyes:] ... although I can see it by eye .... knowing me I'll be putting in new bearings if all measures out well irregardless.
021 by 71240z, on Flickr
So... shortly after a short failured search for the dial-indicator.... I decided to tap the head-bolt threads. Takes a lot of time to do it right , but it's well worth it.
Not much work , but helps motivation
David,always like reading your threads man,Much goodness and progress
Thanks Lou ... appreciated
- Has thanked: 1204 times
...and pics. Sooo many pics.
DRIVEN wrote:...and pics. Sooo many pics.
Well documented
Thanks David
Thanks DRIVEN.. I figured I'd smother everyone in picsDRIVEN wrote:...and pics. Sooo many pics.
510freak wrote:
Well documented
Thanks David
glad someone can decipher my gibberish
Is that a thread chaser tap? I need some of those!
Also.. do you have air in your garage?
Yerp .. chaser tap indeed.draker wrote:Is that a thread chaser tap? I need some of those!
Is quite nice to have a set.
I have a little pancake air compressor
does this count ?
BLUE wrote:Yerp .. chaser tap indeed.draker wrote:Is that a thread chaser tap? I need some of those!
does this count ?
Is it too late to put thread chasers on my xmas list? lol ... Handy tools for sure. What I really want.. is a straight edge. As in.. a true straight edge so I can measure heads and stuff to see how warped they are.
As far as the compressor.. it's air.. but not enough. I was going to suggest roloc disks for cleaning gasket surfaces. It takes like.. 5 min and you're done!
As always.. good work!
loldraker wrote: Is it too late to put thread chasers on my xmas list? lol ... Handy tools for sure. What I really want.. is a straight edge. As in.. a true straight edge so I can measure heads and stuff to see how warped they are.
A true straight edge would be excellent to have !!
I've borrowed one in the past and loved it ... took very good care of it though haha.
lololol ... it is air ... and it's not enough ... just enough to pump up tires ...
lulz
Thank you... also for the tip on the Roloc's !
I apparently like to punish myself with hours of scraping...
I do need to get a real air-compressor .... and apparently Roloc's ! hehe
