izzo wrote:wayno.
where the tcr was originally. it pulled the lca towards the front and center. now it will pull it back to the center, changing the the direction the lca is designed to be, plus changing your caster. do you see that being a problem? Or am i missing how it will work and it will still be pushed in the same direction as stock?
It is basically centered, if I hit a bump or get light in the front, it will pull it slightly back I suppose(1/8 to 1/4 inch at the most), but it does the same thing when in the front, at stock height when you hit a bump(front dips), it pushes it back, but when you get light in the front, it pulls it forward.
When the 720 frame is lowered, it pushes the LCA way back, do most ever take them in and have it re-aligned, no they don't, they are just happy about being lower.
I will work with it, when I did the 521 work truck disc brake conversion, all that had to be re-done, 620 tension rods, 620 LCAs, 720 UCAs(modified), it will all work out in the end, if it don't, I will figure something else out that will work.
The way it was will not work, if I got a flat, it would have hit the ground, that definitely won't work, so this is what I have come up with so far, the only thing I did not consider was that when I turn the front wheels to the left or right, the rear inside of the tire might rub on the tension rod, didn't think of that.
